Gigabyte Rx560 - error 43
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3601
    • slovakia
    hello have this Rx560 that shows error 43. as mostly it is related to memory i reballed all chips and two memory tests show no error.
    so whe can be problem when error 43?
  • dd10
    • Dec 2018
    • 12
    • PL
    Re: Gigabyte Rx560 - error 43
    Try reprogramming the bios
    • fab13
      • Dec 2021
      • 109
      • France
      Hello to you
      . I had the same problem with code 43 and maximum resolution 1024x1080 on my Rx 470. =(
      And unable to install all the drivers. I had to erase the original program and reprogram another BIOS version. Try reprogramming the BIOS with AMDFlash I think. Ideally, save the original bios program on the chips and erase with a programmer found on Aliexpress and then install the correct compatible bios.
      Start by installing a bios from oldest to newest and see if it crashes the system. If nothing does check the voltages on bios and PCI Express level I think. Hoping that the GPU is not faulty. Send a photo with CPU-Z.
      • DynaxSC
        • Apr 2021
        • 464
        • Poland
        It could be that tserver does not detect a memory error, when the memory is only "somewhat" broken, so that it fails on higher frequencies only.
        There is a way to let tserver test on higher frequencies -> You may try the hint from DrasticRepairs at the end of the thread:
        https://www.badcaps.net/forum/showthread.php?t=101715
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3601
          • slovakia
          reball did not help so i found some used rams, replace it and bam. everything works
          • ASB
            Gigabyte MX31-BS1 bios problem (BMC initialize error)
            by ASB
            Bios corrupted after a failed bios update attempt. I searched on the net but didn't find any update/ support for MX31-BS1. I tried MX31-BS0 bios from gigabyte and it worked but now the board is giving the following error. It repeats two times and after the restart, goes to bios setup showing the recovery page. If I shut down/ restart then the error appears again. Kindly provide the original bios of Gigabyte MX31-BS1 or help to solve this issue. Thanks....
            03-21-2023, 09:39 AM
          • macabook
            by macabook
            🧩 Initial Issue
            07-24-2025, 02:17 PM
          • Vesko356
            by Vesko356
            08-11-2023, 03:27 AM
          • greg.chalk
            Asus strix b660-i itx, bios unlock, FPT Error 167: Protected Range Registers
            by greg.chalk
            I updated my pc, from Evga z270 itx to Asus b660-i itx motherboard. In my old z270 motherboard everything whas easy because everything in bios was unlocked (fd, me etc), and could do everything I want.
            Now in my Asus b660 everything is locked (except main bios region). I dont mind so much but I want to unlock bios so I can flash a new splash screen (I have done it with my old motherboard).
            I made a bios dump with FPT (fptw64 -d mod.rom -bios), I modded it and I tried to flash back
            (fptw64 -f mod.rom -bios). I got Error 167: Protected Range Registers are currently...
            10-02-2022, 10:54 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
