HP Elitedesk 800 G4 SFF BIOS/EC firmware error (Code 5.2) - Fixable?
  • surcharge6650
    • Dec 2025
    • 6
    Hello guys,
    I stupidly tried to read out my BIOS & EC flash (with a clamp). This didn't work, I only read FF's. But after this operation, the PC is not longer turning on, just beeps 5 times (and blinks red) then 2 times (blinks white). The manual says this is the error code for: "The embedded controller cannot find valid firmware.".
    I think it locked itself because of my experiment. Is this fixable? I now removed both chips from the board and dumped them, I attach the files in this post hoping someone can help me fix my stupid error. Thanks so much in advance anyone who is reading this. Here is my serial and model number:
    • HP EliteDesk 800 G4 SFF
    • SP# L22110-601
    • PGTXL0GCYC12O4
    • S/N on the casing: CZC912B82Y
    Thanks again to anyone reading this, I'm hoping someone knowledgeable is able and willing to help me out with this.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12651
    Originally posted by surcharge6650
    Hello guys,
    • SP# L22110-601
    • PGTXL0GCYC12O4
    HP EliteDesk 800 G4 Base Model Small Form Factor PC
    • surcharge6650
      • Dec 2025
      • 6
      Thanks a lot for your answer! This is just the BIOS file, correct? I do not have to flash the EC firmware?
      Thanks again, I'm hoping this fixes it, I just wanted to make sure because I have to resolder everything so I want to make sure I'm not missing anything.
      • surcharge6650
        • Dec 2025
        • 6
        Sadly, this didn't fix it. It first booted with error 5.7, which isn't even in the manual. I discovered I didn't solder the EC memory on correctly, after fixing this the old error code (5.2) came back. Any other ideas? Thanks for your help!
        • surcharge6650
          • Dec 2025
          • 6
          Bump
          • intelg
            HP Elitedesk 800 G6 lost BIOS admin password
            by intelg
            Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
            Here is the hardware identification specs:
            HP EliteDesk 800 G6 Desktop Mini PC
            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
            BIOS ver S21 Ver. 02.05.01 01/05/2021
            Born on date: 07/26/2021
            SN MXL11841GN
            SKU 3X8V9UCHABA
            UUID 8116E79EF6FFE94DB0B98A3188270C5C
            SYSTEM BOARD ID 8710
            SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
            11-03-2023, 02:05 AM
          • silentbogo
            HP Z240 need BIOS and EC firmware
            by silentbogo
            Hello everyone. I have a Z240 workstation, and after a power outage it had a bad PSU(already fixed it), and a corrupted BIOS. Initially I had 2.2 blink code, which indicated corrupt DXE region.
            Did a full dump of the original firmware, replaced BIOS region with version N51 from HP website, and now the error code is 5.3(EC firmware unable to communicate with BIOS).
            Flashing the original one as a sanity check also didn't revert the error code(still 5.3). The original firmware version is N01(supposedly it wasn't updated since the original owner bought it).
            I'm wondering...
            12-16-2025, 06:55 AM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • BrentH561
            Elitedesk 800 G6 SFF Bios Password Lock XM25QH128A (3.3v) - Am I doing this right?
            by BrentH561
            Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
            HP EliteDesk 800 G6 SFF
            Serial No: MXL1223499
            Product No: 26S74UT#ABA
            BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most
            08-23-2024, 08:36 AM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
