Asus RX570 - component
  • Fide
    • Dec 2021
    • 5
    • Deutschland
    I need top know which Mosfet driver i must buy for this Asus RX 570 Graphics Card.
    The Asus Part Number: 4J=5A 91P
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Asus RX570 - component
    It's a Richtek device. 4J is the SMD code that should relate to the part number, the other letters/numbers are a date code
    But I wasn't able to find the part number for Richtek code 4J so far
    Follow me on YouTube
    Learn Electronics Repair
      • 21842
      Could be this one rich RT9611CGQW https://cdn.badcaps-static.com/pdfs/...0d9f034a6c.pdf
      • anarquiax
        • Dec 2021
        • barcelona
        thx,.code 4J=5A 91Q
        • Oliver111
          Asus UX535L.Help to find name of mosfet driver
          by Oliver111
          Hi! Please help to find mosfet driver name. Laptop is Asus UX535L. CPU PWM - NCP81215D, Mosfets on CPU - fdpc5030sg. Driver - DYU or DYP, cannot find it on google....
          04-08-2024, 07:47 AM
        • AppleLover123
          Asus X712EA 3 volts after the first mosfet
          by AppleLover123
          Hey guys,
          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
          Now i thought something...
          12-15-2024, 07:49 AM
        • Scotchmist
          Asus GA502D keeps blowing mosfet
          by Scotchmist
          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
          I have removed the mosfet and can run the laptop no problem
          The MOSFET is FDPC5018SG
          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
          08-24-2024, 02:23 PM
        • MicroSMD Lab
          ASUS ROG Zephyrus GPU Mosfet repeat failure
          by MicroSMD Lab
          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
          01-10-2024, 06:36 AM
        • someonenotyou
          ASUS G513R - cannot remove MOSFET
          by someonenotyou
          Hi.
          I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
          I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
          Of course, I did not force it, but tried to lift it up with tweezers.
          Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
          10-10-2025, 11:05 AM
