GTX 980TI with 2 broken pads on memory module
  • foshland
    • Jan 2017
    • 126
    • Spain
    Hi, I got a 980TI with 2 pads broken under a memory module and yes, they are needed pads, so I just cant ignore them. Ill try to fix them but im waiting for the pads and solder mask to arrive.
    Thinking on the worst scenario, is there a way to modify the bios to ignore that module and end with a 5.5 Gb card???? (or 5, or 4, doesnt matter, just dont want to throw it away) Its the 12 of 12 modules, so its the last one. Searched on internet without success.
    Thanks a lot
  • N3Star
    • May 2021
    • 40
    Re: GTX 980TI with 2 broken pads on memory module
    There probably is a way to edit VBIOS, but wouldn't that collide with Nvidia drivers? I'm thinking fake cards, marketed as GTX1050Ti or so, which usually are GTS450 or something like that - they crash because drivers allocate data to memory which doesn't exist on the GPU.
    • DynaxSC
      • Apr 2021
      • 478
      • Poland
      If these are pads on the board itself, you might have the chance to fix them, also with a very thin copper wire soldered to the rest of the path. If these are pads on the memory module, don't waste time, buy a new memory module on Ali, or buy a broken card with same type of memories, and transplant the module. I would not waste time to try to mod the BIOS.
      • foshland
        • Jan 2017
        • 126
        • Spain
        Hi DynaxSC, its on the board, im waiting for pads and UV solder mask and will try to fix them, the board was tried to be fixed with a heat gun (the one you use for removing paint, oh my god!!!) and he ripped the 2 pads, but I could scratch 0.5mm away from them and hope the solder mask holds the temperature when I install the new memmory module. The guy gave me 3 new memmory modules, one tried to install, so with no balls and 2 like new. He ripped too 2 caps from the nearby lines and 2 small resistors, but I have new parts for that.
        N3Star, thanks for your reply too, would you think reflashing with a 4GB 980 bios would be possible? I have all the needed material, but it would be my last option, doesnt matter if I lost 2GB and TI, would be better than nothing.
        Thanks to all
        • N3Star
          • May 2021
          • 40
          I really doubt if flashing 'regular' 980 VBIOS would work - they have different cores. I'm just saying that I believe it would be technically possible to check where memory signatures are stored and replace them on 980Ti VBIOS, but even if You would do that Nvidia driver still possibly could assign data to physically missing memory chips.
          • foshland
            • Jan 2017
            • 126
            • Spain
            Yes, you are correct, lets hope I can repair the pads, ill post a image from microscope next time I work on the card. Thanks a lot
              Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
              This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
              Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
              07-07-2024, 02:34 PM
            • kokodin
              memory mod for amd radeon r7 260x
              by kokodin
              Hello, for almost a year i been trying to make something that seems impossible, or my testing software is lying to me and it works only i can't see that.
              I been trying to mod a memory on radeon hd7790 or 260x from 2 to 4 gb, but it doesn't seems to be as simple as i first thought.
              In theory 2 workstation graphic cards using the same graphical processor have 4gb of memory firepro w4300 has 4 256x32b layout and W5100 has 8x 128x16b layout all use gddr5 memory and internals of the bioses seems to be very similar so i was trying to wing it , but so far it seems either tserver can't show...
              03-28-2024, 03:48 PM
            • DynaxSC
              Each GPU reballing produces different MATS results, looking for root cause ?
              by DynaxSC
              I have an Nvidia card which makes me wondering, what is the root cause for Mats errors. The story is as follows:
              1. When I received the card Mats showed one memory with errors.
              2. Replaced the memory chip, but no change, still same error, so memory chip is ruled out.
              3. Made a carefull reballing of the GPU, MATS showed 3 memories with errors, the one before, and 2 other new chips.
              4. Made a second reballing of the GPU and Mats shows again only one memory chip with errors, the same on as in the beginning.
              5. Made...
              12-11-2024, 07:44 PM
            • ongobongo
              Lenovo E14 replaced ddr4 memory module resulting in no boot
              by ongobongo
              I am still working on an Lenovo e14 AMD notebook with some problems. The laptop booted normally but had a ton of problems with the soldered ddr4 memory. I tried deactivating the memory via bios, but that didn't work.
              As i have a matching donor here, I decided to change the module i suspect to be faulty and exchange it with one of the donors.
              Did so, but now the laptop won't boot anymore.
              Anyone here who already did that and can comfirn, that exchangeing one module alone would work? Or do I need to exchange all 4 of them to make it work?
              06-09-2024, 02:42 AM
              DELL Inspiron 5570 Notebook 5000 Specification for Upgrade or Repair
              This specification for the DELL Inspiron 5570 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5570 boardview and 5570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5570...
              09-06-2024, 07:11 AM
