Gigabyte GV-NX66128DP passive cooling failure
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    I got today 4 GV-NX66128DP cards for free that seem to have the same problems.
    They are based on GeForce 6600 VPU and they use passive cooling...
    In 2 of 4 cards there are some caps bulging. The bulging caps are 1500uF 6.3V KZJ. What is the maker of these caps? Are they quality ones or not? Why they failed?
    1 of the 2 cards without bulging caps has 1500uF 6.3V Rubycon MBZ instead of KZJ.
    At the back side of the cards there are signs of liquid... I didn't have a clue what this could be until I read this:
    "Silent-Pipe Technology
    Fast heat spreading without a sound: Heat pipe is filled with liquid material to transmit the heat generated from the heat source side: GPU side, to the other side of a graphic card. Heat is to be brought by vaporized liquid to the other side of the pipe, then for capillarity force, water from cooled steam will go back to the heat source side to begin its thermal trip again, hence, Silent-Pipe enables a graphic card to run quiet and fast to meet the needs of users who has a preference for tranquility at work."
    Well, it seems it's not filled anymore LOL
    Now what I can do to repair these cards? Should I clean up the boards from liquid and then test them in a motherboard to see if they work?
    Photos of every card's up and down side attached...
  • c_hegge
    • Sep 2009
    • 5219
    Re: Gigabyte GV-NX66128DP passive cooling failure
    KZJ Are made by Nippon Chemi-Con. They are a Japanese brand which is generally reliable, but they have problems with the KZG and KZJ series. I'm not too sure what you could do to fix a water/liquid damaged card, though. wait for one of the other members to fill me in there.
    • yyonline
      • Jul 2009
      • 692
      KZJ are made by Nippon/United Chemicon. A usually reliable brand, but KZG and KZG series have some issues failing early.
      I highly doubt the liquid leaked out of the heat pipe. It's possible, yes, but I've never seen it happen in the 10 years I've been doing computer repair (unless someone tried to modify the cooling, but that's another story). The heat pipe liquid is usually soldered into a copper tube. The residue you are seeing on the back is probably residue which has leaked out of the thermal pad interface material, not the heat pipe. This thermal gap pad is in between the card components and the heatsink. It just happens as it ages. In fact, even a brand new thermal gap pad feels a bit oily to the touch. I usually just clean off the residue. It's hard to replace the thermal gap pad material. You can't just use thermal paste, as there's a gap to fill between the components and the heatsink. Replacement gap pad is rather hard to find. I have a few sheets of it, but I use it sparingly as it's hard to come by. If you care to search for a supplier for gap pad, I use some Thermagon and Bergquist products. I had some luck getting them to send me sample sheets, which is what I use to this day. I've never found a good source for small quantities of the stuff.
      Short version: I'd replace the failed KZJ with Rubycon MBZ or MCZ, or something similarly reliable. The residue is likely from the thermal interface material, not the heat pipe. So I wouldn't worry about that too much. As long as the heat sink gets warm with the card running, it's likely transferring heat just fine. If you want confirmation, unscrew the heatsink screws, and see if the residue is centered around the pads between the card and the heatsink.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Thank you for your answers!
        yyonline, it seems you are right...
        The liquid traces on the boards don't fit with the leaking pipe theory, on the contrary they lead to the thermal pad that is placed among the heatsink and the board...
        I just removed that heatsink from 1 of the cards to confirm that and to test every cap's capacitance and esr with my micro esr 4 meter.
        Bellow the thermal pad some tiny smd parts are placed. How come they don't get shorted by the pad?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Ideally the pads are non-conductive.
          Chemicon KZJ & KZG have heat failure issues.
          A video card is a BAD place for them.
          Also looks like you might have Nichicon HM [the black/white with a X stamp].
          Those made from 2001-2004 were defective due to a manufacturing error.
          Date code would be in the format H0344
          - '03' = year 2003
          - '44' = week 44
          The meaning of 'H' is a super-secret and will only be divulged if you provide the winning numbers for next week's Power Ball.
          Mann-Made Global Warming.
          - Dr Seuss
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            I cleaned the liquid from the cards and tested all of them at that system: intel motherboard, Pentium 4 Prescott 3.06GHZ HT and 512mb ddr2 533mhz.
            I ran 3DMark2001, 3DMark03 & 3DMark05 many times, demo and benchmark mode and didn't have any problems with any of them, even with the bulging ones!
            They get extremely hot though, so I decided to attach a small fan and see if it helps. Well, it helped very much and the system didn't get noisy, so I kept the card with the Rubycon MBZ caps in that pc.
            Now, searching for replacement caps for the others that have Nippon Chemicon KZJ, these are the lowest esr caps that I was able to find at rs site:
            http://gr.rsdelivers.com/product/pan...f/5260976.aspx
            Are they suitable?
            - '03' = year 2003
            - '44' = week 44
            They are Nichicon HM A0527 A0515 & A0517.
            • c_hegge
              • Sep 2009
              • 5219
              That is a 2005 date code, which ARE defective.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                Indeed they may be defective as 2005 is the year they fixed the problem.
                On the card there are 3 very small caps that are G-Luxon, definitely bad caps too.
                But recapping a graphics card is not the easiest thing for me, I don't have an appropriate solder iron (30W with thin needle), so for the moment I will replace only the Nippon Chemicon KZJ caps. Can anyone tell if Panasonic FMs (http://gr.rsdelivers.com/product/pan...f/5260976.aspx) are suitable?
                • yyonline
                  • Jul 2009
                  • 692
                  The FM capacitors are taller than the current capacitors (10x12.5 mm vs 10x20 mm). The extra tall caps may interfere with the card in the next slot, if there is one. Otherwise, the FM capacitors will work fine.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    I haven't seen enough reports of bad 2005 vintage HM that couldn't be attributed to a bad PSU or heat issues which can blow any kind of cap.
                    As I recall I've only even heard of it twice.
                    - One had a questionable PSU and the other was from a Dell toaster-oven case.
                    If you find any then post them here.
                    https://www.badcaps.net/forum/showthread.php?t=4654
                    - Dr Seuss
                    • stavr0
                      • Nov 2007
                      • 21
                      A note for any other owners for this card. In my case, the system is failing
                      frequently with a black screen, so they will eventually become unusable.
                      Gigabyte nVidia 6600LE - 6.3v 1500uF KZJ
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        I replaced the KZJ caps on one of those cards.
                        This was my first time recapping a multilayer pcb and it wasn't easy at all.
                        I used a 40W "top electronics components" soldering iron that I bought some days ago for 7€
                        The hardest part was to remove the remaining solder from the pcb holes.
                        I am very lucky that the thing worked after so much heating.
                        For replacement caps I used Panasonic FM 1500uF 6.3V esr 0.019, while the original caps were KZJ 1500uF 6.3V esr 0.018.
                        I think it is okay.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Good job!
                          Yup, 40 watts is a little 'light' for most thick boards.
                          - Dr Seuss
                          • mikeyles
                            • Jan 2006
                            • 3
                            I also had similiar experience with a Gigabyte GV-R577SL-1GD ATI HD 5770 with silent pipe passive cooler graphics card purchased in 2010. It only lasted till late 2013 (intermitent display issues) and has a total of 3 bulged and small leak started on 6.3V 1500uf KZJ capacitors.
                            I can confirm they are junk.
                            cheers mikeyles
                            • c_hegge
                              • Sep 2009
                              • 5219
                              Yup. a Passive cooled GPU is pretty much guaranteed to kill them. Recap it with a few of these (https://www.badcaps.net/store/produc...roducts_id=147) and it should be right.
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                and put there a silent fan
                                  • 31024
                                  i would use poly's on a passive card.
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2850
                                    • Greece
                                    The temps are so high that the gpu is going to fail eventually.
                                    I got 9 x GV-NX66128DP cards 2 months ago from the university recycling pile. Only 2 worked ok.
                                    With the other cards the system would not boot at all or boot without video or show artifacts. I strongly advice putting a fan on passively cooled gpus unless they are entry level, generating little amounts of heat.
                                    • DynaxSC
                                      GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                      by DynaxSC
                                      I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                      General test conditions:
                                      - Tested with Core i5 6500 and Core I7 6700K - no difference
                                      - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                      What is wrong:
                                      With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                      When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                      03-21-2025, 06:23 PM
                                      Thermal pad thickness for various laptop GPU / Graphics Cards
                                      ASUS Dual RTX 2070 OC 8GB
                                      ASUS ROG STRIX RTX 3080 OC
                                      ASUS ROG STRIX RTX 3090
                                      ASUS TUF Gaming RTX 3080 OC Edition
                                      ASUS TUF GTX 1660 S-O6G GAMING
                                      EVGA RTX 3060 Ti XC GAMING 8GB
                                      EVGA RTX 3060 XC GAMING 12GB GDDR6
                                      EVGA RTX 3080 FTW3 ULTRA GAMING
                                      EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                      EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                      Gainward RTX 2080 Phoenix GS Specs
                                      Gainward RTX 3070 Phoenix 8GB
                                      Gainward RTX 3080 Ti Phoenix
                                      GIGABYTE AORUS RTX 3080 MASTER 10G
                                      02-09-2024, 08:08 AM
                                    • Hondaman
                                      Liquid cooling?
                                      by Hondaman
                                      I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
                                      (After previous generation hardware [Gigabyte] didn't...
                                      05-08-2025, 09:37 PM
                                      A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                      by momaka
                                      More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                      And a shot of the label:...
                                      01-26-2022, 03:26 AM
                                      Gigabyte AORUS 15X Netbook Specification for Upgrade or Repair
                                      This specification for the Gigabyte AORUS 15X Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15X boardview and 15X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte AORUS 15X Netbook...
                                      09-07-2024, 07:19 AM
