Attempt to repair AMD FirePro
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello guys,
    inspired by this excellent tutorial made by dicky96 (this thread), I have decided to try to diagnose and repair faults AMD FirePro v4800 graphics card. This card is about 10 years old and I have another fully functional one, so this should make repair attempt a bit easier.
    First of all, I have checked for shorts and compare as much measurements as I could (multimeter in diode mode) to the working one and couldn't find any significant difference.
    So, when plugged in the motherboard, card is not detected and there is no picture on the screen.
    Since I don't have an extension cable, I need to make all voltage measurements when card is plugged in the motherboard, so not all places are available.
    First a bit history. These cards are known for its fan as a weak point. If operated in a dusty environment, the fan fails after two or three years, causing the overheating problem. This card had overheating issues and it worked without spinning fan for who knows how long before it simply failed.
    After card is plugged in the motherboard and power ON, I was able to measure 12 VDC on two smaller black coils. They are part of the input circuit and together with green electrolytic caps they represent input filters. On two bigger coils I have measured stable 1.1V, and on the coil far right (marked with 1R0) I have measured 0.9V. So, it seems that all voltages are present, but there is no picture. I also noticed that GPU develops a lot of heat, and it is noticeable more hot than working one (even with replaced fan).
    Is it possible that GPU is faulty because of overheating?
    Is it necessary to try to find 1.8V when voltages are present on all coils?
    master hoarder
    • May 2008
    • 12168
    Re: Attempt to repair AMD FirePro
    100% YES.
    Don't take this offensively, but this is like driving your car and letting your engine overheat. Then it broke and you ask, could it be because it overheated? What do you think?
    In this case, you have history of the GPU and you know it was overheating. So no point in wasting time trying to check any components or voltages. GPU chip is probably dead. You can try to bake it / reflow it / re-heat it / burn it with a piece of hot charcoal / whatever other creative heating method you can think of to try to revive it. But if you do, just beware that chances it will come back alive are small. And chances that it will last any decent length of time is pure luck... though generally, the cooler you keep it (provided the reflow even worked), the more likely it is to last longer... though still no 100% guarantee. By keeping cool, I mean keeping under 50-55C max under load. So that certainly means ditching the original cooler and going with something better. And for this kind of card, that probably isn't even worth it, unless you're doing it purely as a learning experience or to have fun.
    All that said, though... don't get your hopes too high the reflow will work. IME, I've gotten about 15-20% success overall with getting a card to come back to life (most cards won't), and only a handful to still continue to work (after cooler mods and whatnot.) In other words, ask yourself, do you feel lucky.
    • Dan81
      SNES-powered
      • Oct 2013
      • 1865
      Considering it's a HD5000 series card (HD5670 to be exact) it should last quite a time. Assuming you use the right thermal paste of course (at least MX4 or MX5 is recommended for those), it should last pretty well. Add a bigger cooler as usually those cards come with poor heatsinks that aren't suitable for anything past HD3200 or 3450 max.
      Main rig:
      Gigabyte B75M-D3H
      Core i5-3470 3.60GHz
      16GB DDR3-1600
      Samsung SH-224AB DVD-RW
      Delux MG760 case
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        No - as you understood from the video, 1.8V must be there by default, if you have PEX, Vcore, Vram - which obviously you do
        Thank you for your kind words - I seem to have inspired quite a few people with that particular video (and even have some reported success stories by viewers who watched it on my YT channel then had a go themselves) so now it is time to blush
        Ahh that's better
        Rich
        Follow me on YouTube
        Learn Electronics Repair
        • Askic
          • Sep 2018
          • 187
          • BIH
          Hello guys and thank you for the replies. I feel I need to add more background information.
          I have two DELL workstation that work as graphics servers with these type of cards. The PCs are about 10 years old. About two years ago, one PC started frequently to shut down by itself. After opening the case I saw that fan on the GPU card is not spinning at all. It was stuck with dust and dirt. The computer could start about used to shut down unpredictably. So, I cut out the existing fan and installed a bigger one on the side. It did the job and this server is today still in function without any issues. Have a look at the attached image.
          Few weeks ago problem occurred on the second server and I also noticed that the fan on the GPU is not spinning, but this time the symptoms were different. Computer didn't detect GPU and there was no picture at all. So I knew that the problem is different and I knew there was a lot of overheating since fan was out of operation for unknown period of time. (The PC is periodically cleaned from dust by compress air once per year or so).
          Anyway I tried to reheat and to re-flow and it didn't work. It was a good and fun experience anyway.
          Do I feel lucky? Almost all the time
          Thank you very much dicky96, because your video tutorial explained the most basic and important things, such as power pins, what voltages are there and similar. I'm sure t will be very helpful, because in future, I'll try to at least measure the voltages on faulty GPU cards instead of immediately replacing them.
          • Christos Tsiligiannis
            Marian Trace Alpha sound card repair help
            by Christos Tsiligiannis
            Hello to the forum.
            My name is Christos, I am new to the forum here and i am posting from Greece.
            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
            So i tried asking for a schematic from the company and they would not give me one. Instead they...
            11-18-2024, 05:26 AM
          • Kemer
            Graphics Card mounting frame
            by Kemer
            Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
            As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
            I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
            What worries me right now is the possibility that...
            09-14-2024, 08:57 AM
            HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
            This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
            09-06-2024, 08:30 AM
          • FZG
            EVGA Nu Audio Sound Card - Not Working
            by FZG
            I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
            The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
            I found...
            03-07-2025, 11:44 AM
          • benwaterson
            Gigabyte Aorus 1080ti - card not initialising
            by benwaterson
            Hi there.
            Have searched various forums but haven't come across the exact issue I am having.
            Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
            I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
            Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
            02-05-2022, 11:42 AM
