it8772e enable pinout?
  • totto210
    • Apr 2021
    • 51
    • chaco
    hi guys..
    need some help pls.
    What pinout is enable in this ic?
    regards
    • 21874
    Re: it8772e enable pinout?
    https://datasheetspdf.com/pdf-file/1.../ITE/IT8772E/1
    Whats the motherboard you`re working on , make/model
    • totto210
      • Apr 2021
      • 51
      • chaco
      im learning with h61 chipsets,(ga-h61m-s1)
      i think, the enable here refer to enable cpu vcore and vldt voltages right?
      not enable ic" is is enable with 3vsb , vbat or Analog vcc right?
      ty so much
      • davodamirajam
        • Apr 2017
        • 9
        • iran
        first ite check 12v if ok
        then check 5v
        after that chech 5volt standby ,3.3 volt standby
        after all voltage ok .pson signal send to h61 chip
        if search youtube /find that
        before do anything. check 5,12 5volt sb ,and dc to dc convertor "5=>3.3 sb"
        may be some capacitor is shorted
        • pickledegg
          Dell Inspiron 7501 / Vostro 7500 (2020) - eDP connector pinout/panel compatibility question
          by pickledegg
          Hello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
          I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...
          10-02-2024, 04:54 PM
        • BC_TechForum_drb
          Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
          by BC_TechForum_drb
          Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
          Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
          Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
          2/ Figure 1 Gfx-D500-B Front Facing
          3/ Figure 2 +5v supply (zoom-in)
          Intro:
          While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
          12-07-2023, 09:55 PM
        • maleksa
          Korg Kross2 Service Manual and LCD pinout
          by maleksa
          The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
          However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
          Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
          From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
          10-11-2024, 05:54 AM
        • AquaMan Ua
          Panasonic toughbook CF-19 help connect the HDD directly. Need a SATA pinout.
          by AquaMan Ua
          Hello, dear community. NEED A DIAGRAM of the HDD/SSD connector contacts as an example (a screenshot from the diagram of another laptop on which I have already done this and a photo of the patient's board) Maybe someone can make a screenshot of the diagram with the pinout? Or does someone have a diagram of the motherboard schematic?
          I am asking, because not find the information myself anywhere. I have a PANASONIC CF19 MK2 laptop (Any revision will do, I do not think that the contacts in the connector are located differently) but finding a basket for it at reasonable prices is a problem....
          08-26-2025, 09:07 AM
        • Talonts
          Dell Latitude 7290 enable touchscreen entry in BIOS?
          by Talonts
          For those that have worked through the 7290 BIOS in the past, do you happen to know if there is a switch in it to enable a touchscreen entry in the BIOS setup?
          The 7290, 7390, and 7490 all use the same BIOS, and the 7390 has an FHD touchscreen as one of its' options. It turns out it can be installed in a 7290 BUT since the BIOS doesn't have the entry to turn it on, it just becomes an FHD upgrade to the 7290.
          I was hoping if any of you that had worked on the BIOS in the past would know if either the touchscreen settings could be turned on in the 7290, or the BIOS could...
          06-24-2025, 11:27 PM
