iMac 21.5-Inch "Core i5" 2.3 (Mid-2017) 820-01069-b
  • alfredodinolfo
    • 128
    • N/A
    Green light only Led #1, #2,#3.
    led #4 is off;
    fan run on;
    no image on external monitor;
    no reset PRAM and no mouse activity.
    I tried to change bios and I verified activity on bios chip.
    No diagram or boardview for this board.
    Anyone have fixed?
    - - - - Board UMA - - - -
  • mon2
    • 14657
    Re: iMac 21.5-Inch "Core i5" 2.3 (Mid-2017) 820-01069-b
    What is the history of the computer ?
    Was it working before someone opened the unit for some upgrade ?
    LED # 4 is a failure to communicate with the LCD display. Check the LVDS cable to the display. Is the blade connector still properly soldered on the logic board ? Trace where the LVDS cable is connected to the LCD and confirm again for a proper connection.
    However if the external monitor is also not working then this is graphics card related.
    Trace the voltage from the power supply to the LCD display. Are these cable harness connections ok? On past other imac models, DIY customers damaged this area and we had to dissect the cable harness (both the LVDS ipex blade connector) and the power cables and re-attach them.
    To confirm, you are not getting the power up chime ? PRAM reset is NOT working for you?
    I would check the voltages on each coil to see if anything is not in a 'normal' voltage range.
    • hvencl
      • Oct 2021
      • Belgium
      Hi all. In my case with this exact model I get first and third led lights coming up and cycling again only first and third. Second one never comes up and fourth if off because the screen is of. I am thinking it could be bad PSU. Appreciate any suggestions.
      • mon2
        • 14657
        @hvencl, try reseating the ram.
        • hvencl
          • Oct 2021
          • Belgium
          Thanks, I tried and got it once to power up with only one Ram stick in. When I got all connected again with one stick in the problem returned. In the meantime I ordered a replacement PSU so I will try again when it arrives.
          • mon2
            • 14657
            Remove the RAM stick. Power up without the ram stick. What are the results?
            If you have another free RAM stick socket, seat your ram inside it and test again.
            Perhaps your RAM is defective.
            • hvencl
              • Oct 2021
              • Belgium
              Update: dismantled everything again, cleaned RAM stick contacts with alcohol, checked the voltage on PRAM battery 2.8 Volts so changed it just to be sure. After that it started without RAM sticks. So I asembled everything with current/old RAM and it works. Restarted it a few times and made a power cycle and so far everything works. I still haven't tried unplugging it (the problem occurred last time I unplugged the computer because I wanted to put it in another room). Could it be that the battery made all these problems
              • mon2
                • 14657
                Good job! I think the cmos battery (coincell) could have been the fault.
                See here:
                https://discussions.apple.com/thread/7961982
                • hvencl
                  • Oct 2021
                  • Belgium
                  So I have to report back again that the computer is not working any more. Now it has only led 1 and 2 on. Led 3 flashes and turns off. No chime, screen is black and fan is on. I guess the GPU died and it is integrated on this model. Tried reflowing the CPU/GPU chip with hot air station but there is no change. Just Led 1 and 2 are on.
                  • letsrock88
                    • Aug 2022
                    • India
                    Hi all I have same problem here. In my case with this exact model I get first and third led lights coming up and cycling again only first and third. Second one never comes up and fourth if off because the screen is of. I am thinking it could be bad PSU. Appreciate any suggestions.
                    So i need board view and schematic diagram for Board No.820-01069-B
                    • Aliencomputres
                      • Aug 2019
                      • 217
                      • România
                      Helo,
                      What is the history ?
                      • sierra1212
                        • Jun 2021
                        • Czech republic
                        Hello ,
                        I have the same board, but different state
                        Green light only Led #1,#3.
                        led #2 ,#4 is off;
                        fan run off;
                        Anyone have fixed?
                        • reformatt
                          • Feb 2020
                          • 1488
                          Most iMac board failures for me are shorted caps, usually towards the bottom of the board where it sits below the screen. Sometimes the short is on a switched power rail.
                          No schematic available for this version of board, closest to it is 820-00034. My strategy would be just to put my meter across caps at the bottom area checking for one that is shorted. Thermal camera helps too if you do find a short on a rail somewhere.
                          • aksel3
                            • Jul 2016
                            • 26
                            • turkey
                            Hello ,
                            led #2 ,#4 is off;
                            fan run off;
                            Anyone have fixed?
                            Power chip issue. change isl62383c if only led 1 and led 3 on led 2 off led 4 off
                            • aksel3
                              • Jul 2016
                              • 26
                              • turkey
                              Power chip issue. change isl62383c and 7568 transistor. if only led 1 and led 3 on led 2 off led 4 off
                              • ryogadan78
                                iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                by ryogadan78
                                Hi guys, I need your help again.
                                I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                06-10-2025, 03:49 AM
                              • Stephen
                                iMac M1 DFU restore issue
                                by Stephen
                                iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                this is the message it gives me with the error
                                Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                03-07-2025, 12:19 PM
                              • Stephen
                                iMac 27” 2020 Boot issue
                                by Stephen
                                Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                                08-16-2024, 09:32 AM
                              • tommy97
                                iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                                by tommy97
                                we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                                Any ideas what might've...
                                04-20-2024, 04:48 AM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
