Help identification component on water damaged MSI 1070 Gaming X GPU
  • ZoOLf
    • Mar 2021
    • 61
    • NA
    Hi gents,
    so i recovered a liquide damaged GPU (MSI 1070 Gaaming X) i try to fix it,
    the corrosion is so bad that it ate some component's pads.
    some are easy identifiable, others are not, from a similaire Boardview (Msi 1080GTX attached) I got some info:
    1-in boardview the component is named SOT23-5 no other info:
    from the pic we can see marking L1C9.
    no datasheet available and I cant find where to purchase it, What other Ref can I use instead.
    2-not available in the boardview but i guess its Sot23 (marking 2A. and N symbole)
    same no datasheet no info where to get it or something similaire.
    you can see in the pic also the component L1117LG which i found it easily in aliexpress.
    3- in boardview the componant is named 0.807v a quick googling gave me Sot23-8 :
    marking ADPG also no info where to get it.
    so any idea with what component i can use instead ?
    the MSI 1080 boardveiw
    PS: a high res of the PCB pic
  • ZoOLf
    • Mar 2021
    • 61
    • NA
    Re: Help identification component on water damaged GPU
    the damaged area is at top left of the GPU,
      • 22418
      The part marked ADPG has a vertical bar on the left, it a Monlithic Power part - https://www.badcaps.net/forum/showpo...85&postcount=3 .The last digit is a year code,so the part number is ADP
      Heres the datasheet https://www.monolithicpower.com/en/d...ocument_id/342 MP1475DJ
      • ZoOLf
        • Mar 2021
        • 61
        • NA
        Thx
        1/3 found 2 remaining :p
          • 22418
          Re: Help identification component on water damaged MSI 1070 Gaming X GPU
          The 1st one L1C9 is an Anpec APL3511A B .The C means 1A/Active High,the 9 is a date code
          https://www.aliexpress.com/item/4000412659922.html
          2 down 1 to go
            • 22418
            I think the part marked 2A is an ON Semi MMBT3906 ,although i`m not 100% sure
            https://cdn.badcaps-static.com/pdfs/...7d924bb6f9.pdf
            • ZoOLf
              • Mar 2021
              • 61
              • NA
              Mr SMDFlea, you re just amazing, thx man i will go with those.
              3/3 down
              • ZoOLf
                • Mar 2021
                • 61
                • NA
                Just came here for feedback, i repaired the gpu, now its working, the only thing missing is the leds system, other than that every things is fine
                • farks
                  • Nov 2021
                  • Phillipines
                  What is the .cad viewer use here?
                    • 22418
                    Thanks for the follow up ,i`m glad its working .
                      • 22418
                      Use Allegro free physical viewer 16/17.
                      • RetroComputingGrotto
                        Water Damaged Toshiba 48L1435DB
                        by RetroComputingGrotto
                        I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
                        The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
                        10-07-2024, 08:23 AM
                      • Tomylee
                        Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
                        by Tomylee
                        I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
                        It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
                        I'm looking for help with the following:
                        The exact identification or part number of the T5 component
                        05-28-2025, 12:42 PM
                      • rzsn
                        water damaged G513I
                        by rzsn
                        Hello friends, so I have got a "water damaged" (or cola/beer/coffe .. something dark and sticky) G513I system - which has the board and schematics from this thread. After cleaning up all the visible sticky residue with water and detergent (thankfully mostly on the top/keyboard side), I have a partial success. IPA was of no use for cleaning this.
                        Using a bench power supply on the DCIN jack (as it seems that the PSU keying pin is not wired at all - series resistor R6003 is not populated), and using a shoring wire for the power button (either pin 5 on CN251 keyboard, or one...
                        12-22-2024, 09:02 PM
                      • phantomEVO
                        [help]820-01521 WATER DAMAGED
                        by phantomEVO
                        HELP! audio board+its flex+powerbtn flex water damaged (an hole on audio board)!!! chnged both, but i have 5v on both ports:
                        https://files.fm/f/6gjpqyjw3q
                        here some measurements
                        ppbus_g3h 12,29v
                        PP3V3_G3H 3,29v
                        pp3v3_upc_xa_ldo pp3v3_upc_xb_ldo 3,27v
                        PP1v8_UPC_XB_LDOD PP1v8_UPC_XA_LDOA 1,8v
                        PP1v8_UPC_XA_LDOD PP1v8_UPC_XA_LDOa 1,8v
                        PP1V1_UPC_XA_LDO PP1V1_UPC_Xb_LDO 1,1v
                        with battery connected, as soon as i connect the cable, i see direclty 20v, but stuck at 0,0250
                        10-24-2025, 04:23 AM
                      • estabilito
                        Dell Latitude E5590(La-f411p) water damaged
                        by estabilito
                        I have water damaged Dell Latitude E5590 around charging ic.
                        Laptop was dead but i replaced some components like capacitors, resistors, resoldered charger(intersil 9538h) but traces under PQ904 dual mosfet(AOE6936) was burnt.
                        I rebuilt traces and both mosfets(PQ904 and PQ905) and after all this work laptop started turning on.
                        I dont have battery so i want to be sure if laptop behaviour is normal before buying.
                        On PL902 i have weird voltage around 5Volts, on battery socket voltage looks normal - 13.5v.
                        Is this voltage on pl902 normal?...
                        03-08-2025, 06:22 PM
