Asrock X470D4U server board.
  • pc1staid
    • Apr 2014
    • 55
    • England
    Hi all. I cant find a forum for server boards so if this post is in the wrong forum, would an admin please move it the correct one.
    I have a customers board here that was working fine pre upgrade with another CPU.
    The CPU that was in situ and working fine was an AMD Ryzen 7 3700X. It was upgraded with a AMD Ryzen 7 Pro 4750G. To make this work the BIOS needed upgrading as well. Stock was version 3.10, was upgraded to 3.30 then for this CPU upgrade it was raised to 3.50. When the reflash had finished, a report that it completed successfully was seen ( not done by me, by the customer). Since then, the board fails to POST.
    There is a POST reader on the board that initializes with 00 then follows this course:- 33-72-36 ( hanges for 30 secs)-90 then starts to count down in increments of -1 every second till it reaches 01 ( hangs for approx 60 secs) the reboots following the same sequence.
    This happens with the new, old CPU, the original 32GB RAM and replaced the RAM with 16GB (2x 8gb), onboard and dedicated GPU, original PSU and a Corsair 850w 80+ Gold PSU.
    I have also reflashed the BIOS with a clean 3.50, then back to 3.30 and back to the original 3.10... even gone back as far as the initial 1.20. I have looked on the QVL for the CPU's and the board does support the 4750G but from BIOS revision P4.20, however this BIOS revision is not available on the Asrock site.
    I have taken measurements across the board via the links (PL's) and I get 0.9/1.2/1.8/3.3/12v readings. There is one link that gives me 2.4v but I have no 5v. Yet a chipmunk in the USB shows I do have 5v there. I also have a good 5v on the PSU, yet nowhere else is there a 5v reading. I have traced back the 5v as best I cant from the USB but I seem to lose it via the layers.
    There is no schematic available. On the link I feel should be the 5v rail there is a reading of 030v in diode mode which I feel is a little low, there is another link in very close proximity that has the same component layout ( caps/ resistors) that is the 1.8v rail and that also reads around the 030v. So whilst I feel this is the 5v rail I can not be certain and therefore at this point I do not want to inject voltage in to see if/ where a short maybe.
    I feel there is no direct corrolation between the BIOS upgrade and the no 5v detection on the board and it maybe just coincidental.
    I am a little stumped now. Details on the board can be found here:- https://www.asrockrack.com/general/p...Specifications
    Any pointers that may help me are greatfully recieved.
    TIA
  • pc1staid
    • Apr 2014
    • 55
    • England
    Re: Asrock X470D4U server board.
    Anyone???
    • waldoalvarez00
      • Dec 2015
      • 57
      • Dominican Republic
      I think you better find out what those codes in the led display mean. Should be in the board manual.
      • waldoalvarez00
        • Dec 2015
        • 57
        https://cdn.badcaps-static.com/pdfs/...baaba2dbb3.pdf
        0x36 PEI_CPU_SMM_INIT
        https://en.wikipedia.org/wiki/System_Management_Mode
        0x90DXE_BDS_STARTED (that means that is trying to boot)
        I saw some ppl on another forums trying with video card and even one guy cooling with a fan the chip that reads aspeed.
        • Exim
          • May 2011
          • 64
          There's a 4.21 Beta: https://download.asrock.com/BIOS/Ser...(L4.21)ROM.zip
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • FeerBaron
            Got in way over my head with Supermicro server board and upgrade.
            by FeerBaron
            Last year I bought a server. It's worked fairly well but had some issues. Some pcie slots didn't work and Xeon v4 is a bit slow and missing AVX 512. Came to realize that the next version up, with skylake uses mostly the same chassis.
            A board popped up on ebay one day being sold for parts. A working board like this is over a grand at best. This particular one was about $125 and I decided to gamble.
            At first it seemed simple enough. According to the description it looked like some mechanical damage.
            Found the missing 560uf cap and thought I was...
            Starts
            01-26-2024
            Ends
            01-26-2024
            01-26-2024, 06:36 AM
          • howardc64
            by howardc64
            Yesterday, 05:17 PM
          • Nivla liu
            Board view for ASRock X370 Killer SLI/ac
            by Nivla liu
            Looking for the board view or schematic for the ASRock x370 Killer SLI/ac, Board died, and I want to see if I can spot the fault and see if it could be repaired,
            Thanks for looking, and if you have the file a big thanks.
            Nivla
            02-17-2025, 06:34 PM
