WD 1TB WD10SPZX HDD clicking non responsive
    Acer ConceptD CN715-71-70GB Notebook 7 Specification for Upgrade or Repair
    This specification for the Acer ConceptD CN715-71-70GB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the CN715-71-70GB boardview and CN715-71-70GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-06-2024, 02:34 PM
  • B0r1s
    Samsung UE49KS7000SXXH - fast clicking sound in standby mode
    by B0r1s
    PSU - BN44-00878A
    Symptoms:
    The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
    A weak clicking sound was coming from the transformer.
    Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
    Progress:
    After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
    01-17-2023, 04:58 PM
  • slimmy182
    [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
    by slimmy182
    Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
    I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
    Looking on google I found this:...
    01-14-2023, 11:55 AM
  • beetle1303
    Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
    by beetle1303
    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
    01-13-2025, 08:49 PM
  • mikelu53
    Samsung UN60D8000YF Clicking BN44-0432A
    by mikelu53
    I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
    The set was working then not,then started clicking.
    Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
    Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
    A schematic or suggestion would be great.
    01-21-2023, 03:14 PM
