Nichicon HD on Intel D875PBZ
  • ZuluLima
    • 35
    • U.S.A.
    I just got a brand new zero hour D875PBZLK C27085-209 and was wondering what the Nichicon HD 1500f 10v does? Its Between the sec. IDE and Dimm socket (circled in red). Next to it is a Rubycon ZL 2200f 16v with a resistior coil (circled in yellow). I am going to recap the KZG and KZE's in the vrm and regulator with Rubycon. I want to replace the HD with a Rubycon, but I don't know if the Nichion HD is a filter for the rest of the Nichions on the board. I would like to get rid of all the Nichicons all together for some Samxon. The Dimms are powered by some nice Sanyo and 1500f 6.3 Rubycon. Should I leave the Nichion HD alone? Has there ever been any problems with the HD series?
  • yyonline
    • Jul 2009
    • 692
    Re: Nichicon HD on Intel D875PBZ
    Nichicon HD and Chemicon KZE are reliable series. I'd say no need to replace those unless you're having issues.
    Chemicon KZG are failure prone. I'd recommend replace with Rubycon MBZ or better.
    • DrewPhillips
      Capacitor Diarrhea - Nichicon PL Series
      by DrewPhillips
      Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
      The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
      03-02-2025, 10:18 PM
    • nick3092
      Mid/late 80's Nichicon Yellow Caps
      by nick3092
      I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
      08-28-2022, 03:56 PM
    • withalligators
      Looking for best replacements for Capxons, but can't find data sheets
      by withalligators
      Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
      1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
      1 x Capxon 1000uf35v...
      03-25-2022, 02:30 PM
    • chth96
      Is there datasheet for nichicon LXJ series?
      by chth96
      I want to calculate capacitor ESR referring to below guide.
      https://forum.digikey.com/t/calculat...-from-tan/2633
      I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
      I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
      Is there anyone who still has old nichicon datasheet which has information of LXJ series?
      11-20-2022, 08:11 AM
    • chth96
      Is there any datasheet for nichicon RT(M) series?
      by chth96
      A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
      https://www.badcaps.net/forum/troubl...e-been-blew-up
      and I finally fixed​ this retro game console by soldering varistor and glass fuse.
      But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
      I have spare console...
      11-28-2023, 03:36 AM
