A1418 820-00431-A Looping LEDs
  • mon2
    • 14735
    Hello. Attempting to repair 2 different logic boards with i5 CPU + 8GB iMAC A1418 2k.
    Each shows the first bottom LED on = power supply is good.
    Power button is pressed -> LED 2 and then LED 3 each turn ON and then reset and recycle to only LED 1 (power supply) ON.
    Checked against another logic board and found that inductor linked to FDMF6808N near CPU is @ 12.x Mohms.
    Yet, on the board with the 'power cycling' is @ 2.x Mohms or lower.
    Should FDMF6808N be replaced? Found some @ MobileSentrix. Weird that ONSEMI / Fairchild is not showing this component.
    Is this an EOL component?
    Welcome any suggestions for this repair. Now also have the DS-809SE tool as of yesterday. Should be able to read out the flash firmware for public posting.
  • StephE
    • Mar 2019
    • 10
    Re: A1418 820-00431-A Looping LEDs
    have you done anything else with that board ?
    I have (had) the same problem (cycling LEDs 1-3)
    First step was checking for obvious visible problems, didn't find any except for an unusally large amount of loose solder balls all over the board on both sides.
    After reassembling the iMac the problem stayed the same for a few minutes, then it changed to LED 1+2 on steady and fan starting/running at full speed.
    Schematics around U7000/ISL6372 of 820-3588 are similar, so i was able to find a short on PPVCCIO_S0_CPU (--> dead CPU) and/or pin 13/14 of U7000 (CPU_VIDSOUT/VIDALERT_L)
    I think i have found/checked all other parts that may short PPVCCIO_S0_CPU, so this board is done for now. Probably killed by a solder ball rolling to the wrong place)
    Is there a datasheet for ISL6372 available anywhere ?
    PS i have succesfully replaced FDMF6808N/FDMF6708N with FDMF3030 (on 820-3662 etc.)
    • mon2
      • 14735
      Hi. Thanks for your comments. With regret, no - had to shelve the repair till later.
      If the fan is running on full speed - check your thermal sensor for the hard drive. It has to be present or as a plan B - run a program to dial down the fan speed but only if you are confident the thermal cooling is ok in your box. For example, if using a SSD, you could run a program to override the fan speed.
      Some logic boards have the need for a 2 pin thermal sensor which can be built using a 5 cent transistor (2N3904):
      https://www.youtube.com/watch?reload...&v=inLZ9_SQOHU
      Before the above noted repairs, your hands could almost burn from the backside of the chassis with over heating. After the new paste & thermal pads - cool as a whistle. Be sure that the large heatsink plumbing is tight on the CPU & video card chips.
      The argument we have is that it took around 10 years for the quirks to be visible. With some fresh thermal paste & pads which have advanced a great deal since this box was manufactured, the fix works.
      Hope to study this unit in the near future.
      Last edited by piernov; 08-04-2021, 06:20 AM. Reason: typical reflow bullshit whatever
      • gabrielA7
        IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
        by gabrielA7
        Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
        I saw that the room LED lights up only when the screen is connected, so quiet.
        We have all the power supplies, even processor, 1.8V
        One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
        I suspect that there may be some leak in the processor.
        Anyway, when I press the power, it...
        10-29-2024, 06:48 AM
      • Pipolups
        Corsair K70 LUX RGB dying LEDs
        by Pipolups
        Hi there !
        I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
        Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
        10-08-2024, 11:58 AM
      • THE GTC
        Insignia NS-37D20SNA14 intermittent LEDs
        by THE GTC
        So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
        When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
        11-03-2020, 02:40 AM
      • pni
        Backlight panel diffuser melt by backlight leds broken
        by pni
        Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
        10-12-2025, 12:08 AM
      • VitalComputing
        Replacing Mode Indicator LEDs
        by VitalComputing
        I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
        I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
        I thought I could just put a resistor...
        09-17-2023, 04:43 PM
