GTX 1660 - Sense Issues PCIEe POWER
  • bogdandeac
    • Oct 2018
    I've got a GTX 1660 with a strange fault. On boot "PLEASE POWER DOWN AND CONNECT THE PCIEe POWER CABLES(s)" message appears.
    Checked and re-checked the 8 pin connector on the board and on the power supply side.
    I've seen that on Sense pin I've got around 3.1V without the connector plugged. If is plugged in it goes to ground.
    I've got some troubles in identifying some components. U16 has an "L2" marking and D6 a "KL7" marking.
    I will need some help in identifying those components. I usually repair graphics card with Power Stage / VRM issues and I don't really understand
    how the sense voltage drop is detected and by who.
    Thanks in advance.
  • leinadri
    • Dec 2020
    • Portugal
    Re: GTX 1660 - Sense Issues PCIEe POWER
    I have the same problem
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Possibly U16 is a 2 input AND gate - what is the part number / SMD code?
      Follow me on YouTube
      Learn Electronics Repair
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • zlr8r
        Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
        by zlr8r
        hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
        Ill try and give as much info as I can.
        Dell Inspiron 17 (7786) Laptop
        Service Tag: 5J0NHT2
        Bios: 1.9.0
        When I received this , it would only flicker on the KB backlight for a second, then off and on.
        Then it started getting weirder!
        Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
        12-12-2023, 09:31 PM
      • sli4
        Original NES power issues
        by sli4
        I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
        I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
        Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
        On the big blue connector I get...
        11-28-2024, 12:52 PM
      • gretti
        MSI Z370-A Pro, works but does not power off or reboot and USB issues
        by gretti
        I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
        The MSI BIOS included the ME firmware for the board. The size...
        10-16-2025, 02:14 AM
