some help identifying a component, on a Zotac 1060 Mini 6gb graphics card, thank you in advance, component that is interrupting the 12v that powers the 5v regulator
some help to identify a component, on a Zotac 1060 Mini 6gb graphics card
Re: some help to identify a component, on a Zotac 1060 Mini 6gb graphics card
@victor-r
What makes you think the component is faulty? You say it interrupts the 12V supply, but you also say 12V reaches the + end? What voltage is on the other end?
FR makes me think like Fast rectifier = Schottky but if there is 12V on the + end and 0V on the other end (and the other end is connected to ground) then it seems likely it is one or two zener diodes in a four pin packageFollow me on YouTube
Learn Electronics Repair
https://www.youtube.com/channel/UCFX...R8UZ2vg/videosComment
Are you sure it is RD and not BD
If it is BD it could be P4SMAJ12 (12v)
Rd would be P4SMAJ54 (54v)Last edited by R_J; 02-19-2021, 05:36 PM.Comment
@victor-r
Yeah I also wondered that. If this has 12V on the ++ end and 0V (ground) on the other end then it is most likely a TVS diode like R__J says (almost the same as a Zener as I thought) so you could just remove it (for now) and the graphics card would still work
If you really want to be sure it is OK, remove it from the graphics card, connect a resistor (a couple hundred ohms, it does not really matter) in series with it, put your volt meter across it and connect it to your bench PSU like this,
0v and meter negative ---->!---meter positive--/\/\/\---PSU positive where...
--->!-- is the diode ---/\/\/\-- the resistor, for the sake of argument use a 270R
Now slowly increase your PSU voltage and read the meter reading. If it is a zener or TVS then your voltmeter will read the same voltage as you PSU output, then at some point as you increase the PSU voltage it will suddenly read zero
At whatever voltage that happens, is the rating of the zener/TVS diodeLast edited by dicky96; 02-21-2021, 05:21 PM.Follow me on YouTube
thanks to everyone who is helping me, i will try to inject voltage with little current, without schematic just like that and check if it works, soon after i will see how to replaceComment
Good day, this doesn't answer your question.
I presume you have your answer anyway.
Well I'm new here (how does one make threads like this?), with a similar problem. I have attached photos.
I am missing a resistor after it got knocked off and flung onto my floor😣😭😭
The resistor is near the Q526 IC (6 pin), top side PCB. To avoid the same problem an in circuit resistance will be fine I guess.
Thanks and much appreciated.
More off topic, does this forum allow posts of untested, non circulating bios ROMs? i.e. salvaged from DOA motherboardsComment
by cekcons1060 6gb zotac - boots fine but on random timings (underload or no load doesnt matter) gpu goes black screen and fan goes full mode. I already tried repasting and chaning thermal pads even cleaning pcb with ipa - Tried with diffrent pc etc. No dice. I flashed bios still same.
There seems to obvious damage. But I know this gpu sufferred cat pee before (you read it right) but i cleaned it.
Anything helps. Thanks.06-22-2024, 09:50 AM -
This specification for the Gigabyte AERO 14W-1060-BK7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14W-1060-BK7 boardview and 14W-1060-BK7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 05:46 AM
by fraser34Hi,
Can anybody, please, help to identify this burnt element on ZOTAC GeForce RTX 2060 6GB 192BIT GDDR6?
It says something like "6UDN..." on it.
Thanks...04-28-2025, 10:06 PM -
by wreckless__looking for schematic/board view for Zotac 1070 mini, 8GB...
also.. if someone could post here the most clear photos
that i can zoom in on of the front and the back of the Zotac 1070 mini..
that is what i really need.... but a board view would be helpful...
On the contrary.. really clear crisp pictures of the back and front of the ZOTAC 1070 mini..
that is what would help the most for me in my case...
i had removed a few resistors from it to use on another GPU.. but i seem to have forgotten the locations of where i took them off... ...06-10-2022, 06:24 PM -
by HaukeHi!
I got a defective mini PC mainboard which I am trying to repair.
I don't know the model of the mini PC and I can't find anything about this board online.
When plugged in with USB-C the board does nothing. But it drains about 1.7W.
I noticed, that one component near one of the two USB-C ports get's quite hot (>80°C).
Since I don't have the schematics, I don't really know what component this is. I assume it is some kind of USB-C power or protection controller.
It is labeled "THAC KHD", has 9 Pins... - Loading...
