Ti4800se 2 caps blew
  • SupraSS
    • Aug 2005
    I've tried browsing the posts but I didn't really find any help, maybe I missed something...
    I've found some replacement Nichicon caps to get from the links posted in the faqs but I'm not sure what ones I need for my vid card. There are so many options, lead and lead free, low impedence, compliant, blah blah. It's giving me a headache. The ones on the card are silver in color, approx 7x12mm, and have the markings 470 10v R1 with a cross scored on the top for exploding. How am I supposed to know what kind I need(in regards to the varieties of lead/compliant/low imedence)? Any help is greatly appreciated. =D
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Ti4800se 2 caps blew
    post a pic.
    you want low esr/impedence
    if they are silver they are likely smt too.
    i often use the panasonic fc series since i have them.gotta get creative to mount them in place of the tiny smt parts though.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      lead/lead free doesnt matter unless you are doing lead free soldering. either is ok otherwise
      • SupraSS
        • Aug 2005
        Ok thank you for the advice. Here is a pic, but it's kinda blurry since my digital camera sux monkey balls.
        The two black tipped ones on the right are the ones that blew.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          too blurry to tell what they are.
          since that camera dont do closeups try placing the card on a flatbed scanner.
          are those smt or thruhole?
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            you are too close to focus for that camera. step back and use the zoom
            they look like thru hole
            • SupraSS
              • Aug 2005
              I have tried that, I just couldn't get it to focus. Yes they are thru-hole.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                ok so you need some low esr 470uf10v caps. The most popular caps used on the forum are Rubycon MBZ, ZL / Panasonic FC / Nichicon PW, PM, and PL which are great for graphics cards, motherboards, power supplies etc. If you dont find 7mm width caps then you might have to be creative about the positioning, like bending the leads of a cap and having it flat on the board or tilted because of the close positioning of other near caps.
                here is also a not completely comprehensive list. If you choose one of these let me double check.
                Nichicon - PM, PW, HV, HD, HC, HE, HM, HN HZ (we do not recommend using HM or HN series presently due to early fails of those series.)
                Nippon Chemicon - NRSZ, NRSX, NRSY, NRSJ, NRSG
                NRSX is probably the best
                United Chemi-con - KZE, KZH
                KZE are used on many boards recently.
                Panasonic - FC, FM, FK, FA
                Panasonic FC are highly available and recommended.
                Rubycon - MBZ, MCZ, ZL, ZLG ZLH, ZA, YXH, YXG
                • OldeCrow
                  • May 2005
                  • 18
                  the black caps as willawake mentioned are 470uf the fc series panasonics will replace that nicely as those are what ive been useing on the nforce4 boards Ive been doing.
                  the panasonic part number for the 10v 470 fc series is eeu-fc1a471 and its 8mm x 11.5mm so it will replace those nicely.
                  The green caps on your board are 6.3v 1000uf and panasonic makes a 10v 1000uf that is 8mm x 20mm eeu-fc1a102L and will replace yours nicely as long as you lay them down or dont plan on running a pci card in your first slot (you shouldnt be anyway) you can install them standing up.
                  I am partial to the panasonic's I have had very good luck with them and they also happen to be easily available in the U.S. through digiKey.com they have a phone number too
                  Video cards seem to be a little different than motherboards in that most of the failures ive seen with these metal can caps seem to be Heat related as in the caps blow sometime around the time your fan finaly dies.. Im running about 50% on my video card recaps about half of them suffer dammage to the GPU from the dead fan.
                  you can see some better photos in my post of a 4200 here:
                  https://www.badcaps.net/forum/showthread.php?t=662
                  and Ill add some after photos to that topic as soon as i get time to take pictures .. now that ive recaped three of them!
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    • USA, Unsure of Planet
                    With Nichicon, PM is the lead-free version of the PL series. I'm not sure whether the Panasonic/Matsushita FA or FK series are available anymore. FC and FM are current, FM being lower impedance. The Rubycon ZLH series is new, lower impedance than the ZL. I'm going to post links to Nichicon's, Panasonic's, Rubycon's, and UCC's catalogs on the FAQ forum. One thing to look for in those catalogs is the diagrams showing the various series in relationship to each other, focusing on rated impedance, size,and rated life.
                    PeteS in CA
                      by momaka
                      03-12-2025, 03:42 PM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • SwedishDiesel
                      Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                      by SwedishDiesel
                      Howdy folks,
                      I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                      10-30-2021, 12:47 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
                    • Foetuss
                      Gigabyte GA-6OXT :: caps question
                      by Foetuss
                      Good evening
                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                      But I was also suprised about the bigger boys, which are 330µF 25V.
                      Could it be they used 25V caps because they were cheaper / available at that time?...
                      02-11-2025, 12:22 PM
