Soyo Kt400
  • bigbeark
    • Jan 2010
    • 661
    Soyo Kt400
    This board has me thinking I should recap it. I'm getting an on-die temp reading of 69C, external is 58C (CPU temps according to BIOS). Fan is 3700rpm AMD, heatsink is aluminum but with copper core.
    Hardinfo is showing me 48C.
    This board is using Silver coloured SACON caps.
    I installed a 128MB video card which resulted in a lockup while running HARDINFO .
    Switched to a 32MB Nvidia card and HARDINFO runs, but I still suspect too hot.
    Is there a relationship between Northbridge temps and cap quality?
    The SACONs I removed from my other SOYO board measured OK as far as ESR and capacitance.
  • swammyw
    predator helios 300 shuts down under heavy 3d load, temps are fine
    by swammyw
    Hi i need help troubleshooting predator helios 300 mboard: LA-F991P
    gtx1060 6gb
    laptop shuts down when benchmarking UNIGINE 3d after 2 minutes
    and temps are normal when monitoring while running, when laptop shuts down it makes bios reset process when turned back on (i have to take battery out otherwise it wont start) otherwise it seems to work fine, rtc battery shows 2.8v
    i updated bios ,tried whitout battery ,whitout rtc battery, with another charger but it did not help with problem, anyone had similiar problem? thanks
    12-08-2022, 06:46 PM
  • silencerar
    Soyo SY-7VBA133 Won't react to power on. Could it be this capacitor?
    by silencerar
    Hi! I have an old SY-7VBA133 that I can't manage to turn on. The power supply works and the processor does as well.
    According to the manual it looks like it should have a 5v indicator led, which doesn't turn on (I really don't know where it's located either)
    I've noticed that it has a capacitor next to the power supply connector that is slightly bulged. Before I try to replace it, do you think it could be the cause for this motherboard not turning on?
    There are 3 capacitors, it's the one in the middle.
    I've uploaded a picture of it here...
    05-10-2023, 04:33 PM
  • gintama
    Soyo Class Action Suit (for bad mobo caps)
    by gintama
    Just came across this page this morning, while downloading some drivers from soyo's site. They have a small image on the homepage:
    The dates are at the end of the summary, and it's pretty late in the game. Not that it makes much difference for me anyway, since I'm not in the US. You still have time to make a claim though.
    Text is reproduced here for ease of perusal.
    From Soyo Group Inc:
    SOYO is proud of its tradition of innovation and quality. However, if we ever...
    10-03-2007, 11:46 AM
  • rattlesnake
    Soyo SY-7VBA133U recap
    by rattlesnake
    Hi guys,
    I'm going to recap this baby. I found it dumped in the street years ago, and now it's time has come. I remember having tested it and it posted back then.
    Original caps are bulged and look nasty. All are SACON
    11 x 1000uF 10v
    12 x 1500uF 10v
    1 x 470uF 16v
    11 x 22uF 25v
    1 x 10uF 25v
    The smaller ones look fine. Should I replace them too?
    I read on another forum that I could replace the 1500uF caps with 2200uF caps. Is that so?
    The thing is I could get Sanyo 2200uF or Capxon 1500uF (or Jackon 1500uF)....
    04-10-2022, 06:47 AM
  • Uranium-235
    Comet Lake laptop insane temps and memory
    by Uranium-235
    I got a new MSI A10M-265. So far it's been pretty good. 15" screen, lighted keyboard. First thing I did was clean the cpu/hs off and apply AS5
    This thing has a boost frequency up to freaking 4.9. When it does the temps max at about 97c
    I've been using ThrottleStop to cap the multiplier to 35 (3.5ghz). It's been keeping it about 94c. Is this a little extreme? is it designed for this? I've gotten mixed results in online searches. Some say it's ok as long as it doesn't hit 100c, which mine has never hit
    Also weird, the single 16gb 2666 stick does not work...
    08-24-2020, 01:15 AM
