Comet Lake laptop insane temps and memory
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    I got a new MSI A10M-265. So far it's been pretty good. 15" screen, lighted keyboard. First thing I did was clean the cpu/hs off and apply AS5
    This thing has a boost frequency up to freaking 4.9. When it does the temps max at about 97c
    I've been using ThrottleStop to cap the multiplier to 35 (3.5ghz). It's been keeping it about 94c. Is this a little extreme? is it designed for this? I've gotten mixed results in online searches. Some say it's ok as long as it doesn't hit 100c, which mine has never hit
    Also weird, the single 16gb 2666 stick does not work in the other slot. My 8gb adata 2666 stick (same LP 1.2v) doesn't work in either slot.
    MSI has no memory compatibility list. This is strange
    It seems the memory has a dynamic latency as well as speed. Never seen this before, but I've read LPDDR4 has a few more capabilities next to regular DDR4
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Comet Lake laptop insane temps and memory
    Silly question....check to make sure the latest firmware is on it?
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3266
      • Singapore
      omg! is this the new standard for modern junk at its finest?! im flabbergasted!!
      • piernov
        • Jan 2016
        • 4439
        • France
        According to Intel Tjunction is 100°C. It's operating under normal conditions below that. At 100°C it'll start throttling to try to maintain the temp below 100°C.
        It's really not something unusual on laptops, and especially MacBook have been operating at those temps for ages.
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          Still beyond infinitely stupid to design a laptop to run the CPU right up against it's thermal limitations. Tjunction may be 100C, however, that's maximum temp. Certainly shortens the lifespan of the CPU and is most assuredly roasting the components around it.
          Permanently Retired Systems:
          Kooky and Kool Systems
          sigpic
          • piernov
            • Jan 2016
            • 4439
            • France
            The actual temp at which the silicon gets damaged is higher than this. Intel doesn't give exact numbers I think, but once it gets to an unsafe temperature the platform immediately shuts down.
            Of course it's always better to keep the machine cooler, but on the other hand people want lightweight, thin and quiet laptops with a lot of processing power, so that's what you get. They're still designed and operate withing specifications, so technically there's nothing wrong with it.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5045
              • US
              Updating the firmware is the first thing I did. The firmware dates were not that different
              There had reports of this chip throttling down. I'm guessing since I rethermaled it before I even started reinstalling windows, it stays below 100c. Still not comfortable with it that close to tj so I used throttlestop
              Performance is actually not too bad even without boost (even when playing borderlands 2, which is very cpu intensive)
              What you think about the ram issue?
              • BigTroll
                • Sep 2010
                • 1317
                • LAMBDA SOND
                I just looked it up and its a 10510u 10th gen and still on 14nm I would send it back and get a ryzen 7 4700u laptop you would save money and have a much cooler running 7nm chip.
                My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5045
                  • US
                  I've been going through ryzen 4 laptops and the only one with what I want is 14" (Nvidia MX330/350). The RTX/GTX series are too hot and take up too much power
                  If the memory slot is indeed broken i'll probably return it to newegg and refund so I can get a different model with a MX330
                  • BigTroll
                    • Sep 2010
                    • 1317
                    • LAMBDA SOND
                    I couldn't tell from newegg but did your MSI have dedicated graphics or just the intel graphics? either way looks like a nice laptop.
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5045
                      • US
                      integrated. This is part of the reason I want to upgrade memory, because it has one 16gb stick. Dual channel increases APU performance significantly.
                      There is a version of this laptop for only a little more that has a MX330 (sort of like a glorified GTX 960M)
                      Heat sink is bigger, but I bet I would have to rethermal both the CPU and Nvidia chips
                      If this one does indeed have a bad memory slot it's still within return time to newegg and i'll try to get a refund and upgrade
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5045
                        • US
                        One thing I love about this is it has TWO M.2 NVMe 2280 slots. I currently have the 512 that came with it and my 970 evo from my now dead lenovo 6 flex
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          Your AS5 needs time to cure, once it has the temps should drop a couple of degrees.
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5045
                            • US
                            Hm, it's staying on high turbo. Barely any CPU usage
                              HP Z2 G4 + 8GB (1x8GB) DDR4-2666 ECC RAM E-2124G Specification for Upgrade or Repair
                              This specification for the HP Z2 G4 + 8GB (1x8GB) DDR4-2666 ECC RAM can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 8GB (1x8GB) DDR4-2666 ECC RAM boardview and Z2 G4 + 8GB (1x8GB) DDR4-2666 ECC RAM schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                              09-12-2024, 02:20 PM
                              INTEL NUC BXNUC10I5FNHCA1 NUC i5-10210U Specification for Upgrade or Repair
                              This specification for the INTEL NUC BXNUC10I5FNHCA1 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NUC BXNUC10I5FNHCA1 boardview and NUC BXNUC10I5FNHCA1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              09-12-2024, 03:28 PM
                              ASUS PN62S-B5103ZD i5-10210U Specification for Upgrade or Repair
                              This specification for the ASUS PN62S-B5103ZD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the PN62S-B5103ZD boardview and PN62S-B5103ZD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS...
                              09-12-2024, 02:30 PM
                              BLUECHIP BUSINESSline N11050 i5-10210U Specification for Upgrade or Repair
                              This specification for the BLUECHIP BUSINESSline N11050 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the BUSINESSline N11050 boardview and BUSINESSline N11050 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              BLUECHIP BUSINESSline N11055 i5-10210U Specification for Upgrade or Repair
                              This specification for the BLUECHIP BUSINESSline N11055 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the BUSINESSline N11055 boardview and BUSINESSline N11055 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
