ABIT KR7A-133 bad caps
  • Electricstorm
    • Jan 2010
    • 5
    I have an Abit KR7A-133 (no RAID) with bad caps. About 1/3 of them are physically bad (venting/bulging). The rest look physically good. I currently don't have a way to test the caps so I was wondering if I should replace them all anyway or just the obvious ones?
    The symptoms (worse over time till it wouldn't stay on) were verticle multi-colored lines that I had to press reset to get rid of them. They might not re-appear for a couple of hours or a few days. And the computer would just turn off and not boot again (non-responsive) until you unplugged it from the wall for a few seconds.
    The caps are Jackcon, Nichicon and Teapo. Caps near the PCI slots appear to be OK. Only bad around memory slots, CPU, AGP slot and Power Supply connector. Actually only two caps are venting. The other bad caps are bulging. All of them around the top of the capacitor.
    So, again, replace the bad ones or replace them all? The motherboard was somewhat working when I finally took it out to check for the problem. Got to where it would not fully boot up. Also, is there a similar Abit motherboard with a kit available that I could use or just order the caps seperately?
    Thanks for any replies.
    Jim Brock
    ABIT KR7A-133
    • 31248
    Re: ABIT KR7A-133 bad caps
    change the lot - saves having to constantly check it or dissasemble it again.
    • Electricstorm
      • Jan 2010
      • 5
      Thanks for the reply. I'll replace them all then. BAD CAPS
      Jim Brock
      ABIT KR7A-133
      • Electricstorm
        • Jan 2010
        • 5
        I got my caps today and was going through them. Everything is good except the 1000uF 10v caps I ordered. I recieved 1500uF 10v caps instead. They are too tall and will interfere with the PCI cards. How can get the right caps or caps that will not interfere with the PCI cards when installed?
        The old caps were just below the PCI slots. The new ones are about a 1/4 of an inch taller than the PCI slots.
        Thanks,
        Jim Brock
        ABIT KR7A-133
        • yyonline
          • Jul 2009
          • 692
          Topcat has 1000uF 10V Rubycon MCZ in 10x12mm, which should clear the PCI slots.
          https://www.badcaps.net/store/produc...products_id=47
          I ordered a few caps from him a few weeks ago. Decent price, very fast delivery, and the capacitors were recently manufactured. All in all, I was very satisfied and would recommend ordering from him. Many other forum members would echo that opinion.
          • Electricstorm
            • Jan 2010
            • 5
            Thanks,
            I didn't mean to appear to be complaining. Was just wondering how to get the right caps and return the wrong ones. I Thought I had ordered the
            wrong ones until I checked my order. It could have been a simple substitution. They just won't work as they are too tall.
            I sent an email to the admin address that came with my confirmation letter.
            I was surprised to recieve the parts so quickly! Great service!! Just need to get the 1000uF 10V caps to finish it up. I would definitely ordr from him again though.
            Can't wait to see if replacing the bad caps will fix my board!
            Jim Brock
            ABIT KR7A-133
              by momaka
              03-12-2025, 03:42 PM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • edith
              Caps and how to find one to replace
              by edith
              Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
              Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
              Thank you!
              06-11-2023, 05:00 PM
            • madscientist750
              Replacing electrolytic caps by solid caps on old motherboards
              by madscientist750
              I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
              I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
              I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
              10-19-2025, 06:10 AM
            • Mattz_GT
              Which caps to replace: ECS P4M800Pro-M V1.0A
              by Mattz_GT
              It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
              I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
              Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
              Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
              PS. Additional diagnostic,...
              01-22-2025, 12:12 PM
