Never assume!
  • tj2
    • Oct 2009
    • 85
    Never assume!
    I recently stopped into a local hardware/feed store looking for an X-acto knife to use as a pin vise to hold a sewing needle to clear circuit board holes. When I explained what I was looking for, one of the owners showed me the PSU board to his Mitsubishi TV that had been damaged by a storm. One of the primary Nichicons was bulged, so he'd removed it and two of the other primary caps from the unit but said that he couldn't find replacements anywhere. I explained to him how to find good replacements on Digi-Key or Mouser, but he asked me to get them for him and put them in. I'm not looking for another career as a repair tech, though it's fun to fix things and solve the puzzles involved, but to be helpful I agreed to put the capacitors in.
    When I got the board back to work, I got ready to take the two remaining primary caps out. We'd been handling this board and he had already taken out two 1000 uF 200 V Nichicons and a 150 uF 450 V Jamicon, so I had assumed that he had discharged the caps. Also, he said that he had taken the board out of the TV more than a month ago. Fortunately, my early electronics training came back to me and I thought that I should short the remaining primary caps to follow proper procedures. One of the 1000 uF 200V Nichicons was live! It made a huge spark and a loud snap. The unit's owner was lucky. He said that he didn't discharge the caps that he took out before unsoldering them.
    I don't know if the repair was successful yet; the owner said that it was fairly involved take the TV apart to get to the PSU. I explained that there could be more than damaged caps and that other damage could cause the new caps to explode when the unit was powered up, or worse. The owner said that he read online that storm damage on this TV was usually damaged primary caps and that the unit still partially worked before he pulled the PSU, so he felt that the chances were good that it was just the caps.
  • smeezekitty
    • Aug 2009
    • 32
    Re: Never assume!
    When discharging capacitors, it is better to use a 100ohm or so high wattage resistor instead of crossing the wires.
    • Tarot Superstars
      How The AC stage of an Adaptor works
      by Tarot Superstars
      Hi. I have been watching videos on how a power adaptor works.
      There is explanation of the rectifier bridge to the pulse width modulator, the mosfet for switching, and opto-couplers, but there is little to nothing about the AC stage of the transformer the powers the primary coil.
      So, I see that the PWM needs DC to work, but I don't see anything about how the AC gets from the mains supply to the transformer stage.
      A transformer only works on AC so where is that part of the circuit.
      I only see Capacitors on the output. Should I assume that the secondary coil and...
      09-27-2023, 01:00 PM
    • DeanWy
      WD Sentinel DS5100 (NAS) boot issues
      by DeanWy
      I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
      It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
      There...
      07-30-2024, 04:13 AM
    • dicky96
      Xilence XP600 600w ATX PSU - No PWM Controller on primary side - how does it work?
      by dicky96
      Hi guys
      I have a faulty Xilence ATX PSU here
      The fault basically is I have two short circuit power transistors on the primary side of the large SMPS transformer - they are 2SC3320.
      There is another smaller transistor on the primary side C3866 which tests ok
      The PSU has three transformers - it looks like the 2SC3320's drive the big one and the C3866 drives one of the small ones. There is a separate PFC PCB with it's own controller and MoSFETS
      There is also a short on the 3.3V output and a near short on 5V - I suspect this probably blew...
      05-11-2021, 07:55 AM
    • ttmi100x
      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
      by ttmi100x
      Greetings everyone,
      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
      Upon closer inspection...
      07-31-2024, 06:36 PM
    • Sebastijan V.
      Samsung UE40K1502AKXXH - flashing LED, no life but still responsive
      by Sebastijan V.
      So, I got this UE40K1502AK(XXH) TV from a friend.
      TV has no picture or sound, but it reacts on remote control and power button on bottom side.
      - When plugged into mains, the LED is red on. If I use remote to power it on for the first time, it flashes 6x then LED remains off. I assume this would be the same as by normal tv?
      - LED also flashes fast when I push any button on remote controller. If I turn it off with remote, the LED will lit solid red. And by next turn-on with remote, it flashes 5x. Also will flash fast when any remote button is pressed.
      - The background...
      03-20-2025, 04:22 AM
