Nvidia GTX980Ti and GTX780 shorted memory
  • TheQuentincc
    • Mar 2017
    • 59
    • France
    Hi, I'm not sure if I'm in the right section but my issue could also happen in laptop (mostly gaming one).
    Basically I have two graphics card with similar design, I've got an issue on memory on both, resistance between ground and the memory power plane is shorted (like around 0.5ohms instead of 50~100ohms), coild are removed so the issue is not on the power delivery side, I'm using a really funky design to power this power plane (18650 cell and small cable) to get around 1~1.5v on this power plane (I don't have any lab power supply yet) and nothing is getting really hot, the only thing getting warm is the core itself, like memory chip aren't heating up as fast as the core (which is still heating very slow), and this is the case on both card, I already pull out two memory chip on the 980 Ti and the resistance increase a bit (from 0.1ohm to 0.4ohms) but now it's time for the chip to getting warm...
    I don't really know what to think about it, I don't know what happen on the 780 before because I bought it like that, with a burned coil and shorted mosfet (on memory power plane), however there was a 2.2ohms shunt resistor between the mosfet and the 12v power plane, so that was limiting the current and the voltage across the memory/core (imc), right ? like nearly 12v was across the shunt resistor and nearly 0v across the memory/core ?
    For the 980 Ti, it was working but it was power throttling, one of the two memory power phase (mosfet) was shorted BUT shunt resistance of this shorted phase was not 0ohms but 10k, so same as the 780, memory/core(imc) were protected because the shunt resistor endorse the load, right ?
    Thanks you for all your responses
  • reessi
    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
    by reessi
    Hello:
    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
    I started on the ACER:
    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
    10-29-2024, 11:31 AM
  • Yanleb
    Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
    by Yanleb
    Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
    I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
    D608, good
    D618 RF101L4S, good (See warning 1 below)
    D619 RF101L4S, good (See warning 1 below)
    D865 RF101L4S, shorted (See warning 1 below)
    IC464 Inverter HA MC74HC1G14, shorted...
    03-09-2020, 12:00 AM
  • modtool
    HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
    by modtool
    Hi to all,
    the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
    I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
    I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
    04-01-2025, 08:22 AM
  • BalkanBoy
    Dead Razer Blade 14 2022, shorted CPU?
    by BalkanBoy
    today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
    Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
    I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
    Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
    I removed coil and injected 0.7V, it draw around...
    09-27-2024, 12:44 PM
  • guizmo1967
    Dell Latitude 5501 LA-H181P shorted power rail
    by guizmo1967
    This is my problem:
    Laptop: Dell Latitude 5501
    Motherboard: EDC51 LA-H181P
    I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
    I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
    I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
    I injected +1.05V - 2A...
    07-25-2023, 06:56 PM
