Motherboard wont post
  • uligli
    • Aug 2006
    • 139
    Hi, i have a 775 mobo and i cut the plastic corners to put a 771 cpu, thats why i fucked this thing up everything was fine unitl one day i was freaking distracted and missplaced the cpu into the socket (incorrect position), now the mobo would power on, lights up & fans on, but wont post, debug codes indicates harware error, so any idea if i can fix it? Would really appreciated any comment to help!
    -Motherboard : EVGA nForce 790i SLI FTW
    -Tried different cpu (775) same problem
    -Dont have other mobo to test the 771 cpu to see if it´s burned or something
    -Did try clear CMOS and take out the bat with no result
  • spi200
    • Jul 2020
    Re: Motherboard wont post
    Just check that your 5v is still good, first thing post looks for. Maybe something blown or pulling it down. ie Short circuit.
    Dave
    • rascao
      • Jul 2020
      • 53
      • España
      when you misplaced the cpu, you try to turn on? or you find out the error before? check all the pins on the cpu socket they are really easy to bend
      • glovecaps
        by glovecaps
        11-25-2024, 04:23 PM
      • Docus
        Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
        by Docus
        Hi everyone 😀,
        I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
        To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
        Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
        1. I already own the exact same model, but its plastic chassis is badly damaged.
        06-10-2025, 04:24 PM
      • Archimedes
        HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
        by Archimedes
        Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
        Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
        Fans are spinning. Blindly could install windows11 and got the device manager...
        07-30-2024, 05:14 PM
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
