Asus A7N8X-X spontaneous reboot
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Board looks in fine condition, no capacitors bulging
    VRM has Nichicon HM 3300uf with 2003 datecodes
    Most of the other capacitors are OST 1000uf
    For testing, it's running a Sempron 2300 which uses 166 FSB, and a single Kingston PC2700 ValueRAM
    Both processor and memory have been tested fault-free in my A7N8X Deluxe
    As an aside, the -X PCB looks identical to the Deluxe PCB, and uses the same capacitors, but the -X is built in China instead of Taiwan, and omits ICs which support features that -X doesn't have, like Silicon Image SATA controller
    Problem is, it will run Memtest without problems for about an hour, then spontaneously reboot
    Reboot is the wrong word, because after this happens it will start rebooting for a couple of seconds, give a single BIOS check OK beep, power off, pause a few seconds, then repeat this cycle
    At this point, only way to get a successful reboot is to leave it a while - a day later, it starts OK again
    Power supply is a CWT 300w, has no problem with any other board, including the A7N8X Deluxe
    Heatsink is mounted correctly, seems to be functional
    -X BIOS is updated to latest 1010, which introduces Sempron support
    Dick Smith ESR meter doesn't show any abnormalities
    I'm reluctant to just scrap the board, but in this case I wonder if I'm flogging a dead horse
    Has anyone had a problem like this, and managed to fix it ?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Asus A7N8X-X spontaneous reboot
    Bump !
    • Toasty
      • Jul 2007
      • 4171
      >>Dick Smith ESR meter doesn't show any abnormalities<<
      That is -usually- okay for -individual- caps. However, you can not test VRM caps on the board. They are in parallel and resistance in parallel is always LOWER than the lowest value component. The meter(s) only go down to .01 resolution. Several bad will not affect the reading, and would falsely give you a .00 indication.
      As an example, take the ESR of 6 caps in parallel with these individual readings:
      .01, 1.0, 2.0, 3.0, 4.0, 5.0 = .00977
      The meter will show .00 and mislead you to thinking they're good.
      If it were mine, all the OST's would go. HM's can fail without any indication.
      You could also be seeing a BGA problem with one of the "bridges". Because of the many early problems with lead-free soldering (cold joints), you may want to check into that. Also, see if either one feels hot to the touch when the problem happens.
      How about swapping out the memory with another or just use one stick at a time?
      Toast
      veritas odium parit
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        OST and bad-date HM should go as preemptive even if not bad yet.
        Mann-Made Global Warming.
        - Dr Seuss
        • mockingbird
          • Dec 2008
          • 5484
          I had a similar problem with an A7N8X-X. Also the -X lacks the dual channel which is ok because the platform didn't use it very well anyways.
          Here was the problem:
          The computer was booting and it said "AMD Athlon XP 3200+" so I thought nothing of it. But then I would get random error messages in Windows until I finally figured out that the processor was a 2500+ and the BIOS was not detecting it properly. (And to top that off, CPU-Z was also reporting it as a 3200+).
          Go into the BIOS and make sure your FSB and Multiplier and AGP and PCI dividers are ok.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            There was a BIOS glitch a while back that caused BIOS's to report:
            "Genuine AMD Procussor"
            in the flash screen.
            Was simply a typo in the base BIOS code [as in AMI or Award or whoever did it, not the mobo manufacturer] so it affected several brands of mobo.
            Got fixed with BIOS updates but it had a lot people chasing their tails for a while.
            A lot of people thought they had counterfeit CPUs.
            - Dr Seuss
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              did you check the psu?
              sigpic
              (Insert witty quote here)
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                And still doesn't
                • Ant3G
                  • 24
                  Got this board yesterday for repair and found 2 KZGs 820uf bad near RAM
                  PC was randomly restarting, BSOD if I'm right
                  maybe it can help
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    I have the same BIOS, and the rebooting sounds exactly like when the Windows kernel detects a problem and reboots, I dunno if it's even possible for Memtest86 and Linux kernel to reboot itself because it got pissed off.
                    That's typical Windows NT kernel-pissed-off behavior.
                    (During Windows' equivalent of a kernel panic) (Windows 2000 and later)
                    But mine has United Chemicon KZGs and still zero problems so far here.
                    And powering off sounds more like the PSU!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      cwt=fuhkyyu caps.
                      also push down on the northbridge while it it doing this.had one in a custom pipe bender do this.running 2k and would bsod and do several loops then power off.a reflow fixed it.
                      • pfrcom
                        Oldbie
                        • Jun 2006
                        • 1230
                        Talk about resurrecting an old thread ....
                        I can't recall what I did with that board, most likely scrapped - if I had fixed it, would have posted the answer
                          ASUS ZenBook UX490UA-77DHDAB1 Notebook 3 Deluxe Specification for Upgrade or Repair
                          This specification for the ASUS ZenBook UX490UA-77DHDAB1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA-77DHDAB1 boardview and UX490UA-77DHDAB1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 09:37 AM
                          ASUS ZenBook UX490UA Notebook 3 Deluxe Specification for Upgrade or Repair
                          This specification for the ASUS ZenBook UX490UA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA boardview and UX490UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS ZenBook...
                          09-06-2024, 08:29 AM
                          ASUS ZenBook UX490UA-IH74-BL Notebook 3 Deluxe Specification for Upgrade or Repair
                          This specification for the ASUS ZenBook UX490UA-IH74-BL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX490UA-IH74-BL boardview and UX490UA-IH74-BL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          09-06-2024, 06:48 AM
                          09-06-2024, 06:30 AM
