XFX GeForce 9600 GT (PV-T96G-YHFB)
  • tirsojrp
    • Nov 2009
    • 6
    I have this card and I want to fix it. It seems the previous owner broke a capacitor and a choke.
    Can some one tell me the details about the missing capacitor? And where can I get both components?
    http://img692.*************/img692/5720/fullfk.jpg
    http://img685.*************/img685/1244/p1000708.jpg
    http://img683.*************/img683/673/choke.jpg
  • weirdlookinguy
    • Sep 2007
    • 1638
    Re: XFX GeForce 9600 GT (PV-T96G-YHFB)
    Here's the closeup of your card from the Newegg picture. The cap is 1000uf, 6.3v. Dunno about the choke, hopefully someone else on here can help you with that.
    • tirsojrp
      • Nov 2009
      • 6
      this cap should do the job, right?
      https://www.badcaps.net/store/produc...products_id=48
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        I can tell you right now you might as well recap all those caps with the letters "FZ" on them, as those are the infamous sacon FZ caps. The purple ones are sanyo OScon's, those are good.
        • tirsojrp
          • Nov 2009
          • 6
          So, I need 2 https://www.badcaps.net/store/produc...products_id=40 and 1 https://www.badcaps.net/store/produc...products_id=48, right?
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            You need to replace EVERY "FZ___" on it.
            They'll pop their tops loud enough to hear it with the case closed.
            Mann-Made Global Warming.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Looks like inductor says 1R0 same as the big square one.
              That would be 1.0uH
              - Dr Seuss
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                1.0uH sounds about right for that application. On the other hand, the current rating should be fairly high. I'd guess something in the order of 5 to 10A, maybe more.
                Since the previous owner seems to have done quite some damage, it's probably a good idea to carefully check the rest of the card for chipped components.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Looks like there is another one of the same on the board but up higher than the pic here shows.
                  Take a look at that one.
                  - Dr Seuss
                  • tirsojrp
                    • Nov 2009
                    • 6
                    The FZ cap. closest to the edge seems to be damaged.
                    Still nothing about the choke, I guess that one will be a little harder.
                    • Brian C
                      • Dec 2006
                      • 156
                      U need a good soldering iron for the recap job. Replace all the Sacon caps if possible.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Those cap pads look like they are set up for both thru-hole and SMD.
                        If they will take thru-hole caps [with wire leads] then Panasonic FM series are an ideal replacement.
                        FM has slightly better ESR and Ripple than FZ, is easy to find, and is usually inexpensive.
                        Only tricky thing is sometimes you have to get FM in 10v instead of 6.3v to get the right diameter to replace FZ 6.3v.
                        In other words the Sacon FZ 1000uF 6.3v 8mm can be replaced by an FM 1000uF 10v 8mm if the FM 1000uF 6.3v 10mm is too big to fit the PCB.
                        - Dr Seuss
                        • Toasty
                          • Jul 2007
                          • 4171
                          Without the board in hand, it's tough to pick out the correct coil. The current rating is important but not ascertainable through these pictures. That said, the following 2 coils are -SUGGESTIONS- and not absolutes. The first could be too low in current rating and go *poof*. The second is very high in current rating and if I were to recommend one, it would be that one. Simply from the viewpoint that it is very likely overrated for this application.
                          1) Is a radial leaded choke, but you can bend the legs a bit to cross the pads. It is rated at 3 amps and looks to be close to the type and size of the other (good) one:
                          http://mouser.com/ProductDetail/Mura...adS26OeULxY%3d
                          2) Is a SMD and although it looks different, it is the same inductance. It is rated at 9.6 amps. The size is also very close (8x7x4mm):
                          http://mouser.com/ProductDetail/Mura...CbBwJkTr9Ts%3d
                          IMO - If it were my board, I'd use solid polymer caps for all the FZ's and the other cap with the black mark at the top of the whole board picture. These boards are "hair dryers" running across those caps especially if you do anything such as gaming.
                          Your other option may be to look for a "dead" or "parts only" board on eBay, and do a swap.
                          Good Hunting!
                          Toast
                          veritas odium parit
                          • Toasty
                            • Jul 2007
                            • 4171
                            Attached your pic files through the forums as ImageShack is notorious for deleting files after 30-60 days
                            [EDIT: Just looked up one on Ebay. It has an actual picture and you can see your broken cap pushed over a bit and with a dent in the can. Must be a common bit of damage.]
                            veritas odium parit
                            • tirsojrp
                              • Nov 2009
                              • 6
                              Hi toasty, can you tell me exactly where to get the caps you recommended?
                              • brethin
                                • Dec 2008
                                • 1907
                                XFX has a double lifetime warranty on that card, provided its not physically damaged, you might want to try and RMA it and get a replacement for free.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  'double lifetime' warranty
                                  I read a book where this vendor was selling Dragon Spray.
                                  Had a lifetime warranty.
                                  You spray in on you and the dragon can't burn you to a cinder.
                                  If it didn't work you could get your money back.
                                  - Dr Seuss
                                  • tirsojrp
                                    • Nov 2009
                                    • 6
                                    Dude... the card had 2 broken components. RMA won't miss that much.
                                    • 370forlife
                                      Large Marge
                                      • Aug 2008
                                      • 3112
                                      Couple major flaws in that product! Wonder if he had anything to protect against being eaten.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        Digikey.com has Panasonic FM. Or you can buy Rubycon MBZ (MCZ would probably work fine too) here from Topcat.
                                          NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                                          The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                                          10-02-2024, 08:52 AM
                                          NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                                          The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                                          10-02-2024, 07:51 AM
                                          NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                                          The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                                          10-01-2024, 01:54 PM
                                          NVIDIA GeForce RTX 4080 (RTX4080) Schematic & Board View
                                          The GeForce RTX 4080 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2022. Built on the 5 nm process, and based on the AD103 graphics processor, in its AD103-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 4080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The AD103 graphics processor is a large chip with a die area of 379 mm²...
                                          10-02-2024, 08:57 AM
                                          NVIDIA GeForce RTX 3070 Schematic & Board View
                                          The GeForce RTX 3070 is a high-end graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA104 graphics processor, in its GA104-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3070. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA104 graphics processor is a large chip with a die area of 392 mm² and 17,400 million...
                                          10-02-2024, 08:48 AM
