AOpen AX4T Motherboard
  • chunky35
    • Aug 2009
    • 12
    taken pictures, cleaned the board, removed the bad capacitors and there is alot now just need to know what i need i made a list just need some advice
    3- Lelon
    RXA 105*c
    L101(m)
    2200uF 16v
    4- Sanyo
    750 Os-Con
    4
    23 105*c
    8- Lelon
    RXA 105*c
    L101(m)
    1000uF 10v
    10-Lelon
    RXA 105*c
    101(m)
    1000uF 6.3v
    1- Lelon
    RGA 105*c
    L037(m)
    220uF 16v
    1- Lelon
    GRA 105*c
    L101(m)
    470uF 16v
    1- Lelon
    SG 105*c
    L101(m)
    100uF 16v
    3- GL
    10uF 25v
    105*
    28-Gl
    100uF 16v
    105*c
    2- Lelon
    CE 105*c
    L101(m)
    33uF 16v
    planning buying from the site
    thanks chunky
  • chunky35
    • Aug 2009
    • 12
    Re: AOpen AX4T Motherboard
    bump i found 5 out of 5 need some suggestions
    • Toasty
      • Jul 2007
      • 4171
      >>bump i found 5 out of 5 need some suggestions<<
      Specifics? Advice for what? Suggestions for what??
      Where are pics?
      Toast
      veritas odium parit
      • glovecaps
        Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
        by glovecaps
        I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
        My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
        The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
        11-25-2024, 04:23 PM
      • Docus
        Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
        by Docus
        Hi everyone 😀,
        I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
        To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
        Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
        1. I already own the exact same model, but its plastic chassis is badly damaged.
        06-10-2025, 04:24 PM
      • Archimedes
        HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
        by Archimedes
        Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
        Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
        Fans are spinning. Blindly could install windows11 and got the device manager...
        07-30-2024, 05:14 PM
      • dragon3x
        After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
        by dragon3x
        Hi, I have some 32 bits computer motherboards that need repair, as they fail to
        power on.
        Here are some examples :
        (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
        switching supply area).
        (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
        than 6.3 V.)
        1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
        I replaced capacitors with aluminum-polymer.
        3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
        03-21-2025, 02:46 PM
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
