Dell SX280 Question and eventually results
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Dell SX280 Question and eventually results
    If they are HM or HN or 85c then it's a good idea.
    Topcat said the 22uF are known to blow in either GX620 USFF or SX280 [pardon my geriatric moment, I don't remember which] and the two are identical layouts.
    Mann-Made Global Warming.
    - Dr Seuss
    • etnietering
      • Apr 2009
      • 379
      I can't seem to locate a series on them, but they're rated for 105C. The only 85C cap is the single rubycon 100uF @ 16v, which I plan on replacing.
      • etnietering
        • Apr 2009
        • 379
        We'll it's been prime95ing for 24 hours now, with no problems I have a 100uF @ 25v Panny FC that I can use to replace the 85C Rubycon in there. Then I should be good! Thanks for all your help everybody
        • etnietering
          • Apr 2009
          • 379
          Well after 115 hours, 27 minutes of the prime95 torture test (error free!), I'm taking it apart again to put in that FC in place of the 85C rubycon, then I should be ready to sell it.
          • etnietering
            • Apr 2009
            • 379
            Well I finally sold it. 75 bucks. Not quite as much as I was hoping, but still a nice 20 some dollar profit When I killed prime95 it said like 1292 hours - no errors!
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
              Dell Thunderbolt Firmware
              by SMDFlea
              Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
              Some models have a choice of 2 different firmwares, it depends on the dell SKU.
              The SKU is in brackets (****)
              EDIT: NVM65...
              01-26-2025, 06:22 AM
            • F R 2568
              Dell Latitude 5420 does not start (no post) need help to find the reason why
              by F R 2568
              Hello all,
              this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
              I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
              If the laptop is only connected to the AC adapter (battery removed):
              When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
              The power/battery...
              01-08-2025, 05:45 AM
