DFI Lanparty NF4 939 Problem
  • bigbeark
    • Jan 2010
    • 661
    Last time I booted this board it worked but the 1st ram slot did not work.
    After a couple of years storage, when I attempt to boot I get the continuous beeping sound. I can't find a manual to download, but I am assuming this has the award BIOS. A search suggests that this is the Ram failing to be recognized.
    There is no sign of bulging caps or damage to the board.
    Do I assume that the memory controller has died?
    I have tried various tested working Ram, and always the continuous beep, no matter which slots are used.
    Will test the CPU ASAP, but the fact I'm getting the beeps means that it's a ram problem.
    Any experience or suggestions? Thanks in advance.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: DFI Lanparty NF4 939 Problem
    Most commonly this will be a bad contact in the RAM slot. Make sure to clean thoroughly with contact cleaner, double check you RAM sticks and the contacts are in good conditions and compatible.
    Memory controller is inside CPU so you can also clean CPU socket and make sure CPU is in good conditions as well.
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3266
      • Singapore
      i've seen plenty of these boards on junkbay. the problem is that i see 99% of them come with kzg caps which are failure prone. for some reason, dfi luvs using kzg and or kzj caps on these boards which are their primary reason for failure. caps can fail without bulging and kzg/kzj fail while sitting unused and unpowered which is what u experienced.
      also check your power supply. a failing psu can also exacerbate issues with failing caps on the board.
        master hoarder
        • May 2008
        • 12175
        Concur with the two posts above me.
        Tried re-seating all hardware first (CPU, RAM, etc.) several times, as that tends to "clean" the contacts good enough most of the time. If issue persists, indeed check for bad caps as Chaos suggested above - especially if you have United Chemicon KZG or KZJ, as they do indeed can go bad when sitting on the shelf (and in general, they are just not good and can fail with use too.)
        • bigbeark
          • Jan 2010
          • 661
          Yes, this board is loaded with KZG and KZJ. I will remove and replace them and report back. Thanks for the heads up.
          • bartx
            • Nov 2019
            • 12
            • Poland
            I'd like to add some words from me. I have 4 of those boards with such issue. One hangs on DFI logo, but on other three two lower RAM slots are not working. Of course it had been tested with dozen cpus and RAM, I also switched a bios chips between them.
            I've found an opinion, that it might be causes by broken balls below the socket. One board lost two RAM slots right after I used a cooler with the spring mount. I decided to unsolder one socket and bought two pieces of 939 sockets on eBay, but looks like they don't have them or they don't ship it, because there is no contact with sell.
            Anybody know any reliable source of 939 sockets? Or maybe I should try the reflow instead the replacement?
              master hoarder
              • May 2008
              • 12175
              You can try reflowing the socket. Just make sure you don't gunk it up with too much flux. Otherwise, that will make the contacts in it even worse.
              As for replacement 939 sockets... eBay doesn't have them? I know they still did a year or two ago when I searched there. I have an Abit AT8-32X that looks like it needs a socket replacement.
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • pkslowk
                Debug Card Error Code and Solution
                by pkslowk
                Sr. Motherboard Debug Error Code Solution
                1 Intel 845 E9 Bios Related Problem
                2 Intel 845 D4 CPU Socket Related problem
                3 Intel 845 37 Bios Related Problem
                4 Intel 845 7C Bios Related Problem
                5 Intel 945GCPE 34 Bios Related Problem
                6 Gigabyte 845 2 Ram Related Problem
                7 IBM Server A6 A7 Ram Mismatch Problem
                8 Asus 845 29 CPU Related Problem
                9 Lenovo I946 97 C-Mos Jumper related
                10 Gigabyte 845 A0 CPU Related Problem
                11 Asrock G31M-VS D7 Bios Related Problem
                12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                01-28-2021, 12:51 PM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • Gibon378
                Problem with stopping audio and video for no reason
                by Gibon378
                PC Specs:
                • CPU: Ryzen 5 1600
                • GPU: GTX 1080 Palit JetStream
                • MOBO: ASRock ab350 PRO4
                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                • PSU: XFX 650W (don't remember what model)
                • OS SSD: ADATA SP920
                • OS: Windows 10 21H2
                Problem description:
                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                11-19-2022, 09:41 AM
              • ja1870
                Intermittent Samsung H4000 TV A/V problem. Failing component, or "reset" fixable?
                by ja1870
                As probably no symptom is unknown to those around here, would appreciate any comments.
                Trying to troubleshoot an intermittent condition for a non-technical senior - remotely.
                When I can get over there, will try a factory reset, but suppose it could be a symptom of a failing cap or other component - and prefer to be forewarned either way, if possible.
                Detail:
                Older 28" (non-Smart) flat screen Samsung UN28H4000AFXZA works perfectly, except when occasionally displays one of two - probably related - symptoms.
                1) Channel displays...
                03-15-2023, 05:17 PM
