Emachine T3092 bad capacitors
  • feelgill
    • Sep 2009
    I have an Emachine T3092 and the power supply went bad. I replaced the Bestec power supply with Logisys 480W. Would not boot. I then noticed the capacitors were blown, (brown dust on the tops). I ordered replacement capacitors with the same specs as the ones blown. I put those on the board but I am getting no video or beeps. All of the internal parts seem to be powering up but I get no video.
    What else should I look for or try?
    Thanks,
    Phil
  • Newbie2
    • Sep 2005
    • 885
    Re: Emachine T3092 bad capacitors
    Probably the Bestec power supply killed your motherboard. They are infamous motherboard killers when they fail (the +5VSB goes way too high on these power supplies sometimes and kills the motherboard).
    Also, a Logisys 480W power supply is not that great.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
      master hoarder
      • May 2008
      • 12175
      Hi feelgill,
      Do you still have the old Bestec that died? If so, look what model it is. Bestec model ATX-250 12E is well-know to kill motherboards, but other models such as the ATX-250 12Z and ATX-300 models should be safe.
      If you did have the ATX-250 12E, there is a considerable chance that the motherboard is dead. However, before making assumptions, there are still a few things you should try, even if you did have that power supply.
      So you say your computer powers on but you get no video. If you press and hold down the power button, does the computer respond by turning off?
      When the computer is plugged in but turned off, does the Southbridge feel warm or very hot to the touch?
      Also, what brand and series of capacitors did you use to fix the motherboard? (the series is usually a 2 or 3 letter code)
      Try and re-insert the RAM as well; if problems persists, remove it altogether and see if the computer beeps or posts.
      Lastly, try your system with a power supply that is known to be good. Logisys are crap like Newbie2 noted. In fact it's possible that the Logisys power supply is the problem.
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
        After all of...
        07-13-2024, 08:14 PM
      • Cama
        Solar Inverter - SMH-II - 2 missing capacitors
        by Cama
        I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
        My model is : EASUN SMH-II 7 KW
        Mother Board : P/N 18947-002401250250
        Maybe the EASUN SMH-II 4.2 KW have the same capacitors
        Thank you...
        09-12-2025, 02:50 AM
      • Ady2017
        Are there any datasheets available for Elna RJG capacitors?
        by Ady2017
        I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
        05-25-2025, 02:19 PM
