Msi H81M-P33 no screen aftes restart-reset
  • Aliencomputres
    • Aug 2019
    • 217
    • România
    Heloo,
    Msi H81M-P33 no screen after restart-reset.
    Bios update to last version.
    Any ideeas?
    Thx.
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Msi H81M-P33 no screen aftes restart-reset
    replace cmos battery with good one... i found that intel cos of me engine is very problematic if cmos bat goes flat
    Im Back... sort of...
    • Aliencomputres
      • Aug 2019
      • 217
      • România
      I ll do later and let you know.
      Thx.
      • Aliencomputres
        • Aug 2019
        • 217
        • România
        reflash bios chip and change the battery solved the issue.
        Thx all.
        • Abu Albani
          • Dec 2019
          • 4
          • INDONESIA
          Adakah yang paham driver VGA MSI H310M-Pro VH Plus MS-7C13 Ver 1.1, Download Disitus aslinya, keterangan Not Support dengan Prosesor
            • 21841
            Post in english please,your post is jibberish .
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
            • spice_disc
              Vizio TV M50-C1 reboot cycle and static on screen
              by spice_disc
              I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
              The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
              09-08-2024, 02:37 PM
