M2n68-AM SE
  • chano76
    • Jun 2019
    • 11
    • Argentina
    M2n68-AM SE
    Hi pals!
    i`m having a problem with this m2n68
    i've tried to figure out my self to not bother you all with these, but i'm on an end road.
    The motherboard had a lot of 6.3V 820MF caps, all blown, i've recaped all of them, but the problem continues
    It only turns on for 2 second and go off. If i unplug the 4 pin CPU connector it`s stay on.
    I've no power on the core, only have 12 volts in the Drain of the VRM on the green square, and no voltage at all on the red squares.
    No VRM 's are shorted, nor hot.
    Any advice will be apreciated
    Regards!!!!!
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Re: M2n68-AM SE
    Maybe a bad CPU VRM controller (if the EC doesn't receive CPU_PWR_GD signal it will likelly turn off the motherboard)
    • chano76
      • Jun 2019
      • 11
      • Argentina
      Re: M2n68-AM SE
      Thanks for your help cpt.charlie!
      it's possible that none of the P0903BDG VMR has voltage in the gate nor the source? only 12 V in Drain?
      • R_J
        • 9602
        Re: M2n68-AM SE
        Have you tried it with a cpu installed? It may require a cpu (VID) before it knows what to set the output voltage to.
        • cpt.charlie
          • Sep 2013
          • 270
          • Spain
          Re: M2n68-AM SE
          The VRM mosfets are driven with short pulses at the gate pin, but as R_J said, you need to install a valid cpu as the VRM controller needs to know the startup VID.
          • tofik
            MOSFET equivalent K8A60DA
            by tofik
            Hello guys,
            I have a shorted MOSFET K8A60DA with the following characteristics:
            Type Designator: TK8A60DA
            Marking Code: K8A60DA
            Type of Transistor: MOSFET
            Type of Control Channel: N -Channel
            Maximum Power Dissipation (Pd): 45 W
            Maximum Drain-Source Voltage |Vds|: 600 V
            Maximum Gate-Source Voltage |Vgs|: 30 V
            Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
            Maximum Drain Current |Id|: 7.5 A
            Maximum Junction Temperature (Tj): 150 °C
            Total Gate Charge (Qg): 20 nC
            Rise Time (tr): 25 nS
            Drain-Source
            07-19-2023, 05:18 AM
          • jkucukov
            Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
            by jkucukov
            I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
            During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
            02-05-2025, 09:27 PM
            Asus M2N68-AM SE2 Motherboard Boardview
            Asus M2N68-AM SE2 Motherboard Boardview...
            10-22-2024, 12:43 PM
          • tantr13
            Lenovo Ideapad 5 14ITL05 not powering on
            by tantr13
            This is my first post so I'm hoping to get some help on this awesome forum. As a preface, I'm an amateur at electronics, especially troubleshooting complicated devices like laptops. However, I'm trying to develop a skill for it so I can learn how these devices work and how to repair them without continuing the wasteful tradition of throwing them away and buying new. 🤮
            I've had a Lenovo Ideapad 5 14ITL05 for a few years now, with motherboard LA-K321P. I would never leave it plugged in unless I was using it, and always turned it off after I was done, but last week...
            06-28-2024, 06:28 PM
          • rddube
            Toshiba 58L1350UC short on Q301 Drain to source
            by rddube
            Need some help in diagnosing all the ripple effects of a failing Mosfet Q301, which originally was a K13A25D which was shorted Drain to Source.
            I replaced it with a P16NS25 which had about the same specs, and the TV powered on for a few seconds, but dropped dead again and Q301 was again short on Drain to Source.
            So started looking at some other components (after removing the shorted Q301) and found diode D301A shorted (took it out of circuit because both D301A and D301B were shorted in circuit, but it turns out D301B is good.
            03-05-2022, 06:05 AM
