Clevo LP200C loose cap!
  • Sylvester
    • Nov 2006
    • 67
    This is an old all in one pc, the owner was complaining about opera and internet explorer hanging and the system was slow, xp home intel 866 and 512mb ram. Whilst cleaning the fan with air I noticed a cap moving (c310 on the left). Looks like I'll have to strip the pc down and resolder it, the pc was running when I got it, lets hope resoldering the cap doesn't end up a dead pc, explain that to the owner!
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: Clevo LP200C loose cap!
    not to mention they are all bad caps, taicon and what looks like jamicon or something else.
    That is also probalby why it was hanging and being slow. Taicon can be bad with no signs.
    BTW that cap is probalby not broken off, it is positioned in a way that it can wiggle about if you move it side to side. Notice the solid white under it and the half white under the middle one. The middle will move like that too if you wiggle them closer and away from the cpu.
    • Sylvester
      • Nov 2006
      • 67
      Its a loose cap, it'll be interesting when I see the other side of the board and it ain't getting recapped, almost a museum piece.
      • Wizard
        • Mar 2008
        • 2296
        Chances this one loose cap usually have many that will about to have bad solder joints as well on these capacitors. See about it will you just to be sure?
        Cheers, Wizard
        • Sylvester
          • Nov 2006
          • 67
          Won't tempt fate, I'll only resolder the loose cap.
          • Newbie2
            • Sep 2005
            • 885
            Last year I recapped an ancient ASUS motherboard, it had a Celeron 466MHz processor and PC100 RAM!
            It surprisingly had Sanyo 1000uf 6.3V capacitors (it was made during the capacitor plague era), I replaced them all with Nichicon 1000uf 6.3V caps. The original caps were still good.
            I did that because that computer is actually still is use by someone, and it was good practice.
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
            • Sylvester
              • Nov 2006
              • 67
              Resoldered cap, time will tell if there's any improvement.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                any update?
                sigpic
                (Insert witty quote here)
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Probably BEFORE the cap plague. The cap plague seemed to not start until at least 2000 (or probably like December, 1999, lol) (EXCEPT for some socket 370 motherboards)
                  Bad caps NOT likely with the majority of late 1990s motherboards.
                  The 1990s was the time when things were almost always made better. And during that decade, most PCs didn't need loud fans to prevent frying.
                  And the worst ones appear to have been made in 2000 and 2001, maybe 2002.
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • mockingbird
                    • Dec 2008
                    • 5488
                    Probably BEFORE the cap plague. The cap plague seemed to not start until at least 2000.
                    Bad caps NOT likely with late 1990s motherboards.
                    This is not the case necessarily. You can find 486 and Pentium motherboards as well as AT power supplies with Teapo caps. Teap was around for a while.
                    It was only when CPUs were going over 450mhz or so that the greater heat output caused the inferior products to show their weakness.
                    But they were perfectly adequate for the older stuff in fact you can even find old EISA and ISA cards with cheapo caps.
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      486s? LOL. It seems like 99 percent of them were made like tanks! And about cheap caps being put on stuff that hardly use power -> I could see that.
                      But in the 1990s, most stuff were built like tanks, IIRC.
                      And Teapo caps seem to not be that bad. At least not bad like the GSCs on Epoxes.
                      In fact, Teapo seems to be better than Fuhjyyu (typically encountered on CWT-made Antec PSUs)
                      Arc A770 16 GB
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        There are about 8+ capacitor plagues depending on how you count.
                        Off the top of my head....
                        1] Low Quality Aluminum in CH and TW caps.
                        - Has always been a problem for decades and still is. - Ongoing problem.
                        2] Caps with the stolen formula Electrolyte.
                        - CH and TW caps made from 2001 to about 2005.
                        3] HN and HM overfill issue.
                        - 2001 thru 2004
                        4] Excessive heat in small form factor cases.
                        - Ongoing problem.
                        5] Heat issues with KZG and KZJ even in normal cases.
                        - Ongoing problem.
                        6] Sacon FZ that look like Solid Polymer.
                        - Ongoing problem. Technically this a specific example of #1.
                        7] Use of 85C caps on mobos.
                        - Presumably an ongoing problem.
                        8] Counterfeit caps.
                        - Ongoing problem.
                        Teapo buys their electrolyte from Japan but they use CH or TW sources for their Aluminum and Aluminum foil so their quality varies with the Aluminum they get.
                        - Teapo has plague #1 and always did.
                        Old boards didn't stress the caps enough to cause the failure [in the life of the board] very often but those caps still had the poor grade Aluminum.
                        Same-same with most [if not all] CW and TW brands.
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          The number 6 makes me pissed! Because I have FZs on my eVGA e GeForce 7600 GS AGP!
                          And the other AGP video card, another GeForce 4 Ti (Not the one I had a while ago) that I got from a PC part recycling facility, is dead now.
                          And the caps look like better ones, it has Sanyo OSCON caps. Also has what looks like polymers with a black stripe and at least 1 with a green stripe.
                          Arc A770 16 GB
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            I've seen the FZ with both blue and black ink. [Not on the same cap of course.]
                            The blue look like Chemicon Poly [same shade of blue even] and the black look like Nichicon Poly.
                            I don't think it was a coincidence...
                            - Dr Seuss
                            • Günter Schuch
                              searching for Schematics & Boardview for Clevo P641HK1
                              by Günter Schuch
                              hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
                              Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
                              05-14-2025, 06:34 AM
                              Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic
                              Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic...
                              10-04-2024, 03:59 AM
                            • Axton
                              Bios for Clevo P670RP6
                              by Axton
                              My laptop has a GTX 1060 installed, but it is not recognized in the BIOS (see attachment). The chip gets warm and the fans spin. I think there is an error in the BIOS.
                              Could there be a switch to activate/deactivate the graphics card?
                              I am also unable to install an Nvidia driver in Windows.
                              Data about my motherboard:
                              S/N: 1TP670RP6310404
                              P/N: 6-77-P670RP6A-N02A-B#10​
                              If anything else is needed, just let me know.​...
                              09-15-2025, 10:28 AM
                            • TecnicaNTT
                              Convert Clevo PC70DD to UMA
                              by TecnicaNTT
                              Can somone please help me unlock or convert this Clevo PC70DD2 BIOS to UMA only?
                              The motherboard just burned a hole in the GPU VRAM VRM circuit and now there is a 19 Volt short spread across the GPU and VRAM side. I isoalted both circuits from the rest and now I can get the laptop to work and display image with integrated Intel graphics but crazy fan spin and shutdown after some minutes because of missing dedicated Nvidia GPU.
                              Laptop: Clevo
                              Model: PC70DD2
                              Serial Number: NPKC70DD2000E0017S
                              Motherboard P/N: 6-77-PC70DD2-N02C-1D
                              Motherboard S/N: NKPC70D...
                              11-12-2024, 05:14 AM
                            • monitron
                              Bios Clevo NL51RU
                              by monitron
                              I am struggling with a Clevo NL51RU linux laptop that does not boot because of a corrupt main bios.
                              I did not succeed to build a new bios. Maybe somebody has more experience with this laptop and can build a working bios for me or has a working dump.
                              Clevo NL51RU
                              ser: NKNL51RU0001D00318
                              Many thanks!...
                              05-27-2024, 11:02 AM
