Bose AWR1-1W (1995) (No Photos)
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Sorry for lack of photos, this was done around 10PM last night, but thought I'd share this with everyone as a bit of help on older tech.
    Got a message from someone on our local "Pay It Forward" group regarding a Bose radio that was, in their words, "only producing static". I went & picked this up from them, and got it home, powered it up, and was greeted with the granddaddy of all loud humming noises. At this point I also observed the VFD display was flickering rapidly. This told me to check the filter caps in the power supply.
    Opening this unit, I was able to locate the caps to the right of the power transformer. All 3 were Nichicons, dated 1995. The largest one, 10000uF/25V, checked good (Likely for the amplifier circuit).
    The next one, a 1000uF/35V Nichicon VR, Tested out so-so (Mind you, using a DMM as I don't know where my checker is), so I swapped this one out.
    The last one, a 470uF/35V Nichicon VX, was our culprit. It was leaky enough that my DMM was reading about 4Mohm resistance across it. Replacing this brought the radio back to life.
    Just sharing this to show everyone that even the best of the best don't last forever. All replaced caps were dated 1995.
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Re: Bose AWR1-1W (1995) (No Photos)
    Update on this: Finally got the tester I ordered awhile back (one of those TC-1 multitesters), and tossed the suspect 470uF cap on it. Measured 127uF with 50 ohms ESR.
    • FALKLAN
      Mercedes-Benz W163 Bose Audio System
      by FALKLAN
      Howdy everyone!
      I have a SUV with a Bose audio system and I'm considering either a system upgrade, or purchasing a complete replacement system while bypassing the integrated Bose system.
      On the Bose side, I have not found any specifications yet. It's a decent system but I'm, at a minimum, replacing all the factory speakers, head unit and adding an amp and two 8" subs. The Bose is a 2ohm system and I'm not certain about this point. In order to use a 4ohm set of speakers (component/loud), I would need to install 2 sets of 4ohm speakers wired in parallel to match the...
      12-07-2023, 11:22 PM
    • saimom
      Asus FX507ZC4 DANJLFMBAB0 REV B I need photos
      by saimom
      Hello everyone!
      Please help me determine which microcontroller was in this place.
      Logically, I guess that this is a ddr4 PWM memory controller and some kind of Richtek, but which one?
      Thise motherboard came after another service, where they say that water got on the controller and it burned down and they dismantled it.
      They did not take photos before the intervention
      The DANJLFMBAB0 REV B board, schematics, boards and photos of the motherboard were not found on the network, but I may have searched badly-((
      Maybe someone has a photo of this piece,...
      12-17-2024, 08:51 AM
    • Steadily7-Colossal0
      bose soundlink color 2 strange behavior
      by Steadily7-Colossal0
      My dad gave me his bose soundlink color 2, claiming that the charging port was loose. I opened it up, plugged it in, probed around with a multimeter, and I can measure 5V all over the board. I wiggle the charging cable around, no change. The port looks fine: sturdy, clean contacts. I measure across the battery wires and I get 0V, so I assumed the battery was the problem. But then a few minutes later after I disconnected and re-connected the daughter board with the buttons, lights were flashing and I was reading 3.3V across the battery wires. The only logical explanation for this I could come up...
      12-12-2024, 03:20 PM
    • mpa2
      Bose Lifestyle 650 remote malfunction
      by mpa2
      I'm trying to fix this RF Bose remote (model nr. 420129) for a friend. After applying supply voltage the display shows the Bose logo, after a short period of time it goes dark and the MCU enters a sleep mode. It wakes up after a key is pressed, the display remains dark all the time after the start up sequence.
      Sometimes it can still be paired with the main unit and you can control it for a short period of time, then the unit stops reacting again.
      The pcb is clean, there are no signs of corrosion. The voltages look adequate.
      I read...
      10-28-2024, 03:10 PM
    • Davi.p
      Reduce the size of photos please..
      by Davi.p
      Hi all, i'm asking all to reduce photos to a more comfortable resolution before post, the better like around 2000x2000, otherwise many PC / Tablets / phones refuses often to load them or has strong defection... today's digital cameras integrated in phones especially are a mockery because them saves photos at enormous resolutions with much less the real definition, so reducing them is only a good deal.. THANKS!!...
      05-16-2024, 12:53 AM
