Powerleap iP3T v2.0 Slot 1 Adapter
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Have acquired two of these.
    They both have crap caps, e.g. 4 of NKCON 10V 2200uF 8mm and
    1 of NKCON 16V 1500uF 8mm. The adapter is run from a molex FDD connector.
    I would like to replace these with something better.
    However, it is critical these replacements are 8mm dia. to fit correctly
    I cannot find any Pana FC or FM in 8mm for these values.
    What other options are available to me given the dia. constraint.
    I guess at a stretch, 6.3V 2200uF 8mm might be available for +5.0V.
    Also, is it possible to run these adapters with Tualatin PIII-S?
    Any suggestions and advice is welcomed.
  • sofTest
    • Aug 2008
    • 361
    Re: Powerleap iP3T v2.0 Slot 1 Adapter
    Yes, if the BIOS support Coppermine processors. However to benefit fully, the motherboard also need to support 133 MHz FSB.
    Be a mensch
    • JEWilson
      • Sep 2007
      • 369
      Appears Chemicon KZJ 6.3V 2200uF at 8mm diameter would fit the bill for the +5.0V rail on this adapter
      Problem is getting a reputable 16.0v 1500uF at 8mm
      Suggestions?
      • totoagung2
        by totoagung2
        Totoagung2: Situs Slot Gacor Paling Gampang Jackpot di Indonesia 2024
        Hadirnya situs slot gacor gampang jackpot Totoagung2 yang menyediakan banyak sekali permainan slot terpopuler terkini yang hadir setiap tahun nya. Tentunya di Indonesia sendiri yang menjadi salah satu negara yang favorit bagi provider game slot. Banyak sekali pengembang permainan melihat negara tanah air Indonesia untuk menjadikan dan mencoba berbagai kesempatan bisnis judi online yakni games judi slot Totoagung2 terbaik dan terpercaya no 1. Hal itu juga dibuktikan dengan sangat banyaknya provider mesin slot...
        01-01-2024, 02:43 PM
      • Lifeisfun
        Trying to troubleshoot DDR4 SODIMM slot with slot tester
        by Lifeisfun
        Hi folks!
        I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
        Eventually I discovered that it was related to moving the laptop.
        Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
        If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
        I removed the board got one of those memory slot testers...
        06-04-2025, 02:26 PM
      • szepesif
        Lenovo Ideapad 3 15IIL05 working perfectly with onboard RAM but it doesn't start when I add a memory into the RAM slot
        by szepesif
        Hey guys!
        I don't know the solution to this problem, but this is definitely not unique and I would like to figure out the solution to fix these in the future.
        I have two identical Lenovo Ideapad 3 15IIL05 laptops with integrated 4GB DDR4 memory. Both work perfectly with that. BUT... if I add any extra memory to the single RAM slot, it never gives a picture. I thought the RAM slot pins would be the problem but no, all pins are solid (I checked them under the microscope). The RAM in the slot has 1.2V, so the voltage is present on the module. I flashed the latest BIOS, so
        04-19-2025, 10:18 PM
      • Byte_76
        Faulty memory slot on Tekram Slot 1 motherboard
        by Byte_76
        I have a Tekram P6PRO-A5 Rev. 1.01 which has an issue with one of the memory slots and with the floppy port.
        When a memory module is installed into the slot which is closest to the north bridge, the board will beep and won't post. The same memory module works in the two remaining slots.
        Also, the floppy drive does not work regardless of bios settings.
        Please help me to identify the possible cause of the faulty memory slot and the floppy drive port as well.
        I have examined the board under my digital microscope and did not find any broken traces....
        04-12-2025, 06:58 AM
      • stormanimal83
        Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
        by stormanimal83
        Hey....
        Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
        my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can“t understand...
        01-18-2024, 02:15 PM
