HP Proliant Does not Start
  • IamPritesh
    • Aug 2017
    • 356
    • India
    I have this motherboard which does not start at all. Upon investigation I can the board getting slightly burnt on display port 1 connector.
    I noticed that one of the capacitor located near that display connector was damaged and I removed it. Now I can sorting on the adjacent resistor.
    Can anybody please guide me what should be the next step for proper troubleshooting. I have attached the images which may help. If anyone wants any specific image , just ask, thank you.
    CAP C1151 damaged - Removed
    R1170 is also short to ground - Not Yet removed.
    Thank you everyone.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: HP Proliant Does not Start
    Post high-res pictures of both sides of the board.
    • IamPritesh
      • Aug 2017
      • 356
      • India
      These arent not the high resolution images but they could possibly work. If you need any specific area images then I can focus on that area as well.
      • IamPritesh
        • Aug 2017
        • 356
        • India
        sir were these images of motherboard of any use @piernov
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          When I see burns like that, I honestly am not sure if this is fixable. This being a newer mobo, pretty much everything is integrated in the chipset. So the damage near the DP connector likely damaged either the chipset or the CPU (whichever one of these drives the DP signals).
          But before we conclude anything and since the motherboard does not turn on... check the resistance between each power rail on the 24-pin ATX connector (i.e. 3.3V, 5V, 12V, etc.) to ground and post what resistances you get. Anything below 100 Ohms could potentially be a short-circuit or a partial short-circuit. Also do the same test for the CPU 4-pin 12V connector. This will allows us to know if the motherboard/PSI is not turning on due to a shorted part. If that's not it, I'd say the chipset is gone... or if you are very lucky, there may be a switch chip before the DP signals go to the chipset. Just follow the data lines on the DP back from the port to whatever chip it goes to.
            HP ProLiant xw460c ProLiant 5120 Specification for Upgrade or Repair
            This specification for the HP ProLiant xw460c can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProLiant xw460c boardview and ProLiant xw460c schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
            09-12-2024, 02:15 PM
            HP ProLiant xw460c ProLiant X5260 Specification for Upgrade or Repair
          • XxMicroSoldering
            ASUS Rog Strix G17-712LV Laptop Liquid damaged
            by XxMicroSoldering
            Hello Guys
            I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
            10-17-2024, 10:45 AM
          • Tomylee
            Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
            by Tomylee
            I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
            It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
            I'm looking for help with the following:
            The exact identification or part number of the T5 component
            05-28-2025, 12:42 PM
