Problem with mechanical keyboard
  • capullaco
    • Aug 2010
    • 40
    I have a James Dlonkey 619 keyboard, which lately has been having problems with the "2" and "A" keys, so I opened the keyboard to change the "Pause" and "Scroll Lock" switches for the "2" and "A" ones.
    One of the problems, is the mini usb PCB connector, was badly soldered, and it had some glue to make the connectors stand still (I already removed the glue in the pics):
    https://imgur.com/l7hKrpT
    https://imgur.com/T90CeYi
    So I used a logitech mouse cable instead, since it has the same connector, but the keyboard doesnt work. It lights for a second, blinks 3 times, then turn off. Could it be because it needs that small PCB? the other side of the USB is just plain, doesnt have any component besides the USB connectors.
    I also thought it could be because one of the leds (they are on the top of the switch, you can see them on the second pic, those 2 small solders on top of every swtich, with a + sign) fell, and I soldered without checking if they were placed correctly (the + sign), since I dont know it makes a difference or not, so I desoldered this led, but still the same problem.
    What could it be?
    • 31015
    Re: Problem with mechanical keyboard
    you wired it wrong,
    that lifted track goes to a pin you need.
    search usb pinouts and you will find what you need
    • capullaco
      • Aug 2010
      • 40
      Thanks, I bought a USB mini breakout board, will see if that fixes the problem.
        • 31015
        yea, you can buy small pcb's with mini or micro usb sockets on them for breadboarding - i have some.
        get them in 10's for a $ or 2 on ali-express.
        • SDNarcia
          Dell 15R-5521 keyboard problem (KBC?)
          by SDNarcia
          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
          As additional information,...
          07-20-2024, 10:47 PM
        • MrDadosz
          Lenovo Legion 15IMH05 keyboard problem
          by MrDadosz
          Hello, I have lenovo legion 5 15imh05 (board: nm-c911) and I have a problem with a keyboard.
          When I hold power button for ~30 seconds or unplug RTC battery keyboard will work only one time. After laptop reset or shutdown, keyboard won't work.
          In 90% cases when I unplug power supply and turn on laptop on a battery, keyboard works even after plugging power supply - I can't turn on laptop with a power supply and get keyboard working.
          Shortcuts Fn + F1-F12 are working. Keyboard is fine.
          I replaced IT8176FN-56A and reprogram it with a dump from previous chip and it worked for...
          08-15-2024, 05:07 AM
        • fmajbour
          Acer Nitro 5 model A515-51 keyboard problem
          by fmajbour
          I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
          Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
          i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
          I have check the keyboard connector on the mainboard every thing looks ok.
          Then i replaced the keyboard with new one ......same problem exact same keys problem.
          I need your advice if anyone face...
          11-13-2023, 09:50 PM
          HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
          This specification for the HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse boardview and 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
          09-06-2024, 06:21 AM
          HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
          This specification for the HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
