Possible Bad Caps
+ More Options
Posts
  • krazykev64
    • Feb 2009
    • 49
    Possible Bad Caps
    Hope someone can help me. i have been given a Gigabyte 8S661FXMP-RZ (Skt 478) which will not post. Not even the fan on the CPU will spin. the PSU is working. there are three makes of caps on the board
    1/ RUBYCON (genuine spelling) with letter K on top
    2/ OST with a CROSS on the top
    3/ not sure of branding but there are some caps marked KZG with a THREE POINTED STAR on the top
    the OST caps ar slightly bulged on the tops. the others look ok. none of the caps are showing signs of leakage. i have enclosed 2 pictures of the motherboard
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Possible Bad Caps
    KZG are Chemicon.
    That series of Chemicon doesn't like it where it's hot. [Next to CPU, video card, RAM.]
    Will sometimes fail with no bloating.
    Same with Chemicon KZJ series.
    Same with OST. [Probably all series']
    At a minimum replace all of whatever the bloaters are from 6mm/ up and 470uF/up.
    Mann-Made Global Warming.
    - Dr Seuss
    • avoidz
      • Mar 2010
      I've just noticed some of the big green 'K' capacitors on the same board of mine are bulging/leaking, resulting in some random power problems (the display just goes off).
      One directly below the CPU assembly next to the Northbridge; and between the CPU assembly and the RAM sockets.
      I don't have the skill sets to replace these bad caps myself, so it's another mobo to the scrapheap.
      • japlytic
        • Oct 2005
        • 2086
        The three-pointed star is Samyoung, a Nippon Chemi-Con ally.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          change the bulged ones and try it.
          those are vrm input caps.16v
          • c_hegge
            • Sep 2009
            • 5219
            If it has KZG written on it, it's chemi-con. Samyoung usually have their own branding on their caps.
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
