DELL Dimension 4600C
  • webster13045
    • Mar 2009
    hello im new here looking for some help
    i have a Dimension 4600C and im trying to figure out the easy way of finding bad caps if someone could forward me that would be great thanks
  • weirdlookinguy
    • Sep 2007
    • 1638
    Re: DELL Dimension 4600C
    There's this amazing website, I don't know if you've heard of it, it's called Google.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Don't mind him. - He bought their stock so he sends everyone there.
      If they are bloated/leaking it's easy. Look at them.
      If they aren't bloated or leaking you need an ohm meter, an ESR meter, and soldering equipment. (Can't check caps in parallel without removing them.)
      Mann-Made Global Warming.
      - Dr Seuss
      • weirdlookinguy
        • Sep 2007
        • 1638
        No stock here PCBONEZ, but we do have very detailed instructions complete with pictures on the badcaps.net homepage. It just rubs me the wrong way when people start asking stupid questions without even attempting to look around.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I hear you on that one but he's looking for an easy way to find bad caps.
          There isn't one, so he isn't going to find it even with google.
          - Dr Seuss
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • SwedishDiesel
            Dell Dimension PSU Compatibility - B110 PSU in 4550
            by SwedishDiesel
            Howdy folks,
            I've risen from the grave to ask more questions about old obsolete Dells.
            I've acquired a Dell Dimension 4550 which is in need of a PSU - I've several PSUs from Dell Dimension B110s, and I'm wondering if one of them could be used. The PSUs and the 4550 use a 20-pin connector and a 4-pin connector.
            The issue is, I've been told that Dell really likes using proprietary hardware, and there were concerns about damage being caused by an incompatible supply. Because of this I'm assuming it's not just a simple plug-and-play and that there's more...
            12-18-2022, 06:58 PM
            Dell Dimension 8200 Schematic
            LA-1221...
            10-04-2024, 07:48 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • master3112
            by master3112
            07-29-2025, 01:55 PM
