ASRock K7S41GX No Boot No Beeps
  • Solder Boy
    • Nov 2006
    • 178
    Hi just recapped this ASROCK mobo as stated in the title of this thread it's a 462 socket. CPU chip is warm when you take it out. Attached a speaker and I heard no beep codes or anything.
    Tried different chips and RAM all to no avail. Checked the CMOS battery it was fine. Board doesn't shut off at all.
    Faulty BIOS perhaps?
    www.bcrelectronics.ca
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: ASRock K7S41GX No Boot No Beeps
    yep. those boards tend to kill themselves by corrupting the BIOS...
    a reflash (hot-flash in another board) should fix it (if there's nothing else wrong with it)..
    did that about a dozen times now..
    • Harvey
      • Apr 2007
      • 264
      Check the C5706 that's next to and powers the northbridge, I've seen a a few of those boards where it fails open circuit.
      • Solder Boy
        • Nov 2006
        • 178
        Thanks for the info I didn't see that particular capacitor number near the northbridge. The ones near it are CE13,CE14,CE17,CE19,CE18.
        • N3Star
          ASRock X99 Extreme4 boots only on cold boot
          by N3Star
          The motherboard in question boots only on cold boot - if I cut power to the PSU it will boot fine, but as soon as I reboot from Windows or even short reset pins it goes into bootloop - 1 second on, a few off and so on.
          Initially the board arrived to me broken - bad PCH, after replacing it it worked for a while. I suspected a bad connection, but pushing the IC down does nothing. I don't really think that the PCH is dead, since it still boots and works fine until I reboot the PC. Obviously I tried looking for something that heats up or bad caps, but nothing so far....
          10-25-2025, 02:53 PM
        • Weissnix4711
          ASRock B650I Lightning WiFi no boot
          by Weissnix4711
          I'm having some trouble with an ASRock B650 board, any help would be appreciated. Appears to boot at first, turns PSU on, fan spin, but does not post. no display output, beep codes, or anything.
          Tracing signals after power button press,
          PSIN and PSOUT work as expected,
          SIO asserts PSON and the PSU turns on.
          RSMRST# jumps to 1.5V then immediately starts decaying over ~200us.
          SLP_S3# and SLP_S4_s5# stay high throughout.
          Further power good signals:
          ATXPGD, PWROK0 and PWROK1 (labelled O_PWROK1, SIO_PWROK and...
          03-30-2025, 05:58 AM
        • privato89
          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
          by privato89
          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
          Let's begin:
          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
          03-26-2024, 06:37 AM
        • Grucha98
          Asrock Fatal1ty B450 Gaming-ITX/ac wont boot, cpu phases turn off after a few seconds. Bios?
          by Grucha98
          Hi I'm working on that asrock motherboard. It had shoted mosfet on cpu phase(changed) and 1 cap on bottom side(changed). Led driver is probably shotted too because voltage on one leg of this chip is 0.5v to 5v (its in loop rising and falling) its's RT7905 and i cant find datasheet :/ But its only led driver so mb should work without it. When i desolder it on the same leg is 5v all the time.
          If i start mb on all cpu phases is 1v1 for a few seconds only. Other voltage are present. So i tried to flash bios with the newest on official site and it doesnt help. Its not normal extension...
          01-19-2025, 03:40 PM
        • Luke Anders
          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
          by Luke Anders
          A few details about the laptop itself:
          Name: Lenovo Legion 5
          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
          BIOS Version: GKCN60WW
          EC Version: GKEC65WW
          Serial Number: PF39AQ7Z
          Board Model: NM-D562 Rev 3.0
          RAM: 16GB Installed, DDR4 (brand new)
          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
          I bought this laptop recently from eBay as a faulty device....
          10-12-2024, 05:13 AM
