ASRock B650I Lightning WiFi no boot
  • Weissnix4711
    • Jun 2023
    • 13
    I'm having some trouble with an ASRock B650 board, any help would be appreciated. Appears to boot at first, turns PSU on, fan spin, but does not post. no display output, beep codes, or anything.
    Tracing signals after power button press,
    PSIN and PSOUT work as expected,
    SIO asserts PSON and the PSU turns on.
    RSMRST# jumps to 1.5V then immediately starts decaying over ~200us.
    SLP_S3# and SLP_S4_s5# stay high throughout.
    Further power good signals:
    ATXPGD, PWROK0 and PWROK1 (labelled O_PWROK1, SIO_PWROK and PWROK_PS in boardview) are high. good.
    SYS_PWROK (from CPU) stays low
    I don't understand the ACPI power sequence properly, so please any help is appreciated.
    Boardview attached.
    Thanks,
    Thomas
    • 22426
    Please post the boardview in a new thread in the Bios & Schematics requests forum https://www.badcaps.net/forum/troubl...matic-requests ,then post a link to it from this topic
    • Weissnix4711
      • Jun 2023
      • 13
      https://www.badcaps.net/forum/troubl...wifi-boardview
      • lsanhueza
        • Aug 2025
        • Chile
        Boardview attached.
        Thanks,
        Thomas
        I'm having the same problem. Were you able to fix it? The file link no longer works. Does anyone have it?
        Thanks.
          • 31316
          flash the bios using a usb stick and the recovery button if it has it
          • lsanhueza
            • Aug 2025
            • Chile
            I already did that, and it didn't work. It couldn't be done via USB, so I used a programmer instead. The board boots up, but nothing else works.
            • Weissnix4711
              • Jun 2023
              • 13
              Thanks.
              Not sure why attachments seem to be broken rn, but here it is again: https://filebin.net/tr0tuyocu94y0qdx The link might expire eventually.
              I never fixed the problem. The board is still sitting in my 'to fix' pile.
