IBM 49P1599 Rev 1.1
  • Solder Boy
    • Nov 2006
    • 178
    IBM 49P1599 Rev 1.1
    This is a stumper or maybe I have done something wrong, this is an IBM motherboard and when I initially fired it up before recapping it, it didn't POST and no beep codes at all.
    The bad caps in question were 16V 3300-3900 uf one by the 4pin ATX connector, one by the chipset and 2 directly behind the onboard video port.
    I didn't have the exact replacement caps for these so I went down to 10V 1800
    Well good news is now I get 1 beep indicating normal post ( but no picture on monitor) Bad news it waits maybe 2 minutes then I get 1 long beep followed by 2 short beeps.
    Checked the rest of the caps and they all test fine.
    Oh ya boad turns on by itself.
    www.bcrelectronics.ca
  • Lance Thornton
    • Jan 2005
    • 84
    Re: IBM 49P1599 Rev 1.1
    You can's go lower on the voltage if the originals are on the 12 volt rail. Otherwise, you've created a small ticking timebomb. Personally I'd try again with the same capacitance and voltage if possible. Good luck.
    • Ymotaqi
      ROG STRIX Z590-A GAMING WIFI has no POST no BEEP no diag LED
      by Ymotaqi
      The motherboard does not POST and has the following symptoms:
      When the power button is pressed, the fans and RGB turns on.
      When the power button is pressed, the motherboard voltages 12, 5, and 3 are connected.
      The motherboard does not beep.
      None of the diagnostic LEDs light up.
      USB voltage is off.
      VCORE voltage is off.
      The BIOS software was downloaded from Asus site and installed using the Q FLASH button, but it made no difference.
      I would appreciate it if anyone could guide me on the cause of the problem.
      01-12-2025, 04:15 AM
    • piernov
      NVidia bumpgate
      by piernov
      Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
      Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
      May complete this post at a later date with more details.
      Basically issue is a combination of thermal dissipation of the chip with hotspot,...
      03-27-2021, 10:34 AM
    • MisterAIL
      PS5 digital / No Power / No Beep / Good power supply
      by MisterAIL
      Brought a non functionnal PS5. Apparently only a bad PSU...
      No beep, nothing.
      After some tests i found this :
      - PSU is fine (12 volts stable)
      - 12 volts line is shorted
      - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
      - By the way, nothing change. No signal, no power, no beep.
      Mesuring all rails with my workbench psu (12 volts input)
      - 0.00 amp drawing
      - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
      03-12-2024, 03:24 PM
    • ktmmotocross
      Ps5 pro - one beep and not start after hdmi port change and decoder ic reflow
      by ktmmotocross
      Hello.
      Have this ps5 pro EDM033 that came with damaged hdmi connector. i replace it and console works for few days but show hdmi problems when cold start. so cold joint. reflowed connector and decoder ic as i think he have cold joint. but now i have only one beep and no start. can heatdamage of this decoder ic prevent start?
      i have ps5 repair guide but not ps5 pro so link me to it if u know it
      04-27-2025, 01:10 AM
    • teokarafou
      Lenovo Ideapad 5 15ARE05-2 beep
      by teokarafou
      Hello team ,I a have ideapad 5 ,that has a weird issue ,it start up and does 2 beep ,and when I want to type password to login,keyboard doesn’t work ,check video
      Lenovo ideapad 5 15are05
      s/n: pf2hngt3...
      12-27-2024, 08:40 AM
