MS-7699 Fans Spin But No life
  • steved271
    • Jan 2014
    • 29
    • England
    Hope someone can help me here, i have an issue with this board, Tested CPU, Memory and all other components in another board and it fires up properly using same PSU
    Any troubleshooting help would be fantastic as all caps look ok
    master hoarder
    • May 2008
    • 12175
    Re: MS-7699 Fans Spin But No life
    Post a picture or two.
    Just because the caps look good doesn't mean that they are, especially if they are a non-Japanese brand.
    What's the brand of the PSU you are using.
    CPU and RAM specs? Check with the motherboard's user manual to make sure you haven't missed something, like hardware incompatibility with the components you are using.
    Does the board beep with no RAM? (make sure you have a PC speaker connected to the header)
    Reset CMOS and check CMOS battery voltage already?
    Have a PCI POST card handy? Most old motherboards will show activity on it, if they are not completely dead.
    *EDIT*
    I see this is a newer AMD motherboard with an ATI chipset. Thus, you could also be having a BGA issue. Most likely the ATI Northbridge, but also possibly the CPU socket if a stock warp-a-ton AMD heatsink was used. In either case, then the board would need a reflow. But first check the above items.
    Another thing worth checking is the LAN chip and LPC SIO - does any of them get very hot? If so, the motherboard may have been a victim to a lightning strike.
    • steved271
      • Jan 2014
      • 29
      • England
      Sorry for delayed response, I will check all the above and get back to you, I do recall no beeps when ram and cpu isn't installed... Will check for hot chips..
        master hoarder
        • May 2008
        • 12175
        You cannot test the board without CPU. If you do, you won't get any beeps or any meaningful results, so don't do that. Always test with a CPU *and* CPU heatsink installed... with thermal compound! I know some people skip that because it saves time, but it can also damage the CPU or cause the board to panic when the CPU throttles, and thus not POST. I used to tell that to my coworkers all the time and they never listened 'till all of our test CPUs went bad "for no reason" or "out of the blue", as they said.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
          Acer Spin SPIN 1 SP111-33 Hybrid (2-in-1) 1 Specification for Upgrade or Repair
          This specification for the Acer Spin SPIN 1 SP111-33 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SPIN 1 SP111-33 boardview and SPIN 1 SP111-33 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 08:40 AM
        • Fam787
          HELP! A1398 Dead,
          by Fam787
          I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
          Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
          12-27-2024, 05:19 PM
