Gigabyte GA 8S661FXM No Post No Beep
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Gigabyte GA 8S661FXM No Post No Beep
    Well we wouldn't wanna violate and copyrights or anything HERE would we... LOL
    Mann-Made Global Warming.
    - Dr Seuss
    • EGuevarae
      • Nov 2008
      • 1336
      Just giving the credit to the one deserving it. After all, a lawsuit is the last thing I need now that I don't have a job anymore ...
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • Windows 10 Pro x64
      • GeForce GT1050
      • swartz
        • May 2009
        • 31
        Good thing you've told me. I was just about to get on the phone with my lawyer to have you brought up on charges of copyright infringement. I was gonna sponsor my next computer upgrade on the proceeds of the case.
        On a more serious note. I got a hold of a 775 socket Celeron D for purposes of testing. The owner swore that it works. I popped it in to the mobo, plugged in a known good PSU and a working stick of 512MB DDR400 ram. When I flipped the switch both fans (4pin CPU and 3 pin case) started spinning and then shut down after a few seconds. So at least the power is flowing.
        However when I shortcircuit the -POW+ pins I get nothing. It wont boot up.
        Any ideas how to proceed now?
        • swartz
          • May 2009
          • 31
          I've checked the CPU compatibility list on Gigabytes website. The celeron D 330 chip I have is in fact compatible with this board but only from firmware version F4. I dont know what firmware I have on the mobo, but there is a good chance its is not the latest.
          Could this have an impact on the mobo not working completely? I'd venture to guess that at least it should start or make some beeps if it at least sees the cpu.
          • EGuevarae
            • Nov 2008
            • 1336
            It may have some impact. When I install CPUs (or someone else does) and they are not compatible, normally the MoBo comes to life but no video is shown. In rare cases, the system tries to turn on and then shuts off. That might be your case.
            • GeForce GT1050
            • swartz
              • May 2009
              • 31
              #26
              Damn it. After soldering four 2200 uF 16v caps I have no luck booting it.
              Nothing I have tried so far made it work. The fans speed when I flip the switch on PSU, but when I short -POW+.... one big NOTHING...
              Arghhhh... frustrated.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Have you tried resetting the CMOS? [BIOS]
                - Dr Seuss
                • EGuevarae
                  • Nov 2008
                  • 1336
                  Sounds like a victim of a Worstec PSU ... are you sure it was working?
                  Also, the suggestion from PCBONEZ might help. Some MoBos don't turn on/post with a corrupted CMOS.
                  • GeForce GT1050
                  • lucky13
                    • Aug 2007
                    • 412
                    #29
                    I am not sure on Gigabyte boards but I know on Asus boards if you have a newer CPU than the BIOS will support, you will not get POST (it appears to be DEAD, no beep, nothing, nada). You can try to borrow a CPU that the original BIOS will support to carry further.
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      thats why i've got a normal Celeron (not Celeron D) for testing motherboards..
                      Celeron D = Prescott core = not all boards support it
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        That's right. Get a Celeron CPU to rule that out.
                        • GeForce GT1050
                        • swartz
                          • May 2009
                          • 31
                          #32
                          Just to update.
                          Yes, I have tried resetting the CMOS via the jumper as well as removing the battery when all power cables are unplugged. No go.
                          I obtained a Pentium 4 530 for testing purposes. But much like the Celeron D it is only supported in the latest BIOS. No one I know has an older 775 chip. Damn it.
                          I shall try to take the mobo to one of the computer stores, maybe they have a chip we can test right there and then. I hope they wont charge me some ridiculous amount for 5min of their time.
                          • seanc
                            • Nov 2008
                            • 1319
                            #33
                            I've a few of these boards at work, in various degrees of flaky functionality, I'll confirm the caps on them for you.
                            Not a clue *why* they're flaky - they've all been 'repaired' by Gigabyte when they previously didn't work at all.
                            Edit: Must apologize for bumping an older thread if it's against forum rules. Scrolling through the thread I saw 06-11 and thought 6th November, didn't look at the last post date.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Check the PSU's.
                              They may be bummers.
                              - Dr Seuss
                              • seanc
                                • Nov 2008
                                • 1319
                                #35
                                They've been tested with new PSUs, other boards have been put in their places which run fine.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Start looking at the 4 & 5 mm caps then.
                                  - Dr Seuss
                                  • DynaxSC
                                    GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                    by DynaxSC
                                    I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                    General test conditions:
                                    - Tested with Core i5 6500 and Core I7 6700K - no difference
                                    - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                    What is wrong:
                                    With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                    When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                    03-21-2025, 06:23 PM
                                  • pkslowk
                                    Debug Card Error Code and Solution
                                    by pkslowk
                                    Sr. Motherboard Debug Error Code Solution
                                    1 Intel 845 E9 Bios Related Problem
                                    2 Intel 845 D4 CPU Socket Related problem
                                    3 Intel 845 37 Bios Related Problem
                                    4 Intel 845 7C Bios Related Problem
                                    5 Intel 945GCPE 34 Bios Related Problem
                                    6 Gigabyte 845 2 Ram Related Problem
                                    7 IBM Server A6 A7 Ram Mismatch Problem
                                    8 Asus 845 29 CPU Related Problem
                                    9 Lenovo I946 97 C-Mos Jumper related
                                    10 Gigabyte 845 A0 CPU Related Problem
                                    11 Asrock G31M-VS D7 Bios Related Problem
                                    12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                                    01-28-2021, 12:51 PM
                                    Thermal pad thickness for various laptop GPU / Graphics Cards
                                    ASUS Dual RTX 2070 OC 8GB
                                    ASUS ROG STRIX RTX 3080 OC
                                    ASUS ROG STRIX RTX 3090
                                    ASUS TUF Gaming RTX 3080 OC Edition
                                    ASUS TUF GTX 1660 S-O6G GAMING
                                    EVGA RTX 3060 Ti XC GAMING 8GB
                                    EVGA RTX 3060 XC GAMING 12GB GDDR6
                                    EVGA RTX 3080 FTW3 ULTRA GAMING
                                    EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                    EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                    Gainward RTX 2080 Phoenix GS Specs
                                    Gainward RTX 3070 Phoenix 8GB
                                    Gainward RTX 3080 Ti Phoenix
                                    GIGABYTE AORUS RTX 3080 MASTER 10G
                                    02-09-2024, 08:08 AM
                                    A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                    by momaka
                                    More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                    And a shot of the label:...
                                    01-26-2022, 03:26 AM
                                  • nikovmiroslav
                                    Gigabyte A5 X1 Need Bios
                                    by nikovmiroslav
                                    Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                                    Gigabyte A5 X1
                                    From motherboard:
                                    S/N: 1TNH55ER1350895
                                    P/N: 6-77-NH55ERQY-D02-2CGB
                                    On sticker from the back of the laptop:
                                    S/N: SN21351J000657...
                                    08-24-2025, 09:15 AM
