Diamond XtremeTV PVR550 PCI - Bloated Teapo
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Just for the record...
    Board has 8 lytics.
    - All are Teapo SC series, 220uF, 16v, 6x11 mm, with 2.5mm lead spacing.
    - On this card cap date code is: Sept 2004.
    One of 8 is bloated big time. - Others visually okay.
    Teapo's data table does not show a 220uF/16v in a 6mm can.
    (Only shows one in 8mm diameter.)
    Looking at the other caps in the SC table the Ripple for this 6mm is probably ~300 and ESR ~.220.
    Chemicon LXZ [ELXZ160ELL221MF15D] fits by diameter and lead spacing.
    It's Ripple/ESR are 400/.180 -> so better than the SC.
    Mann-Made Global Warming.
    - Dr Seuss
  • iMic
    IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
    by iMic
    Hi folks,
    I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
    The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
    11-29-2023, 06:44 AM
  • bauto601
    KDM 480W PSU upgrade succes! (opinions?)
    by bauto601
    Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
    A "nice" YoungYear unit? - Badcaps
    The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
    12-26-2023, 03:05 PM
  • capfiz
    Diamond Core Drill ELU SB43EK, Blown Capacitator
    by capfiz
    Hi, new to this forum and new to most things electronic component related.
    As in my introductory post, I'm good for soldering, fixing up the grandkids console games but that's about it.
    I am based in the UK.
    17 odd years ago I purchased an ELU diamond core drill, model ELU SB43EK, I had never heard on the brand here in the UK at the time but it has been a faithful tool and has undertaken a number of jobs without issue.
    Last week it failed to start when depressing the trigger, initial checks, it wasn't the fuse or plug top, delving further and...
    11-24-2023, 07:31 AM
  • Alfieh
    NAD C320BEE repair possibly bad capacitors
    by Alfieh
    hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
    recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
    11-19-2024, 04:55 PM
  • abajor
    HP Pro Book 460 G11 Board DA0X8VMB8G1 REV:G Slow Clap for HP Bad ram shield to component spacing.
    by abajor
    Had someone drop off a laptop in which they were upgrading the ram but forgot to unplug the battery.
    Looks like the ram RFI shield shorted a rail going to or coming from a Silergy IC which blasted a component off the board. I'm going to assume it was a cap but really have no way to know for sure since this board schematic doesn't appear to be in the wild yet.
    I'm trying to identify the IC model now but it doesn't appear to match any of the Silergy codes from https://www.badcaps.net/forum/troubl...-tablets-and-m...
    11-01-2024, 12:50 PM
