Question about video card recapping
+ More Options
Posts
  • riva2model64
    • Feb 2009
    I have a friend who broke a capacitor off of a video card. He tried to solder it back on but got the polarity reversed, but we had already powered on the card before we realized that. No visible signs of damage. Is is possible that the the whole graphics board is fried, so that it is not worth it to replace the cap?
    It is an expensive graphics card to replace.
  • Leopard
    • Mar 2008
    • 109
    • Finland
    Re: Question about video card recapping
    Usually one reversed cap is not enough to do permanent damage to the core / memory chips, especially when it was powered only for a short interval. You should just replace it with a good equivalent capacitor from a trusted brand.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      I agree with Leopard.
      You did not run power backwards through anything except the cap.
      Cap is probably the only thing that got hurt.
      Mann-Made Global Warming.
      - Dr Seuss
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        cap should pop after a short time. i remember we had someone here who did that and the board was ok.
        • riva2model64
          • Feb 2009
          Thanks for the responses everyone. That's relieving to hear. The card in question is a 9800 GX2, and the capacitor is a Sanyo OS-CON 16v 180uF from the SVP series, surface mount type as outlined here:
          I checked the North American distributers sites as provided in the FAQ, but they didn't seem to carry the Sanyo OS-CON series.
          So I looked on ebay for a while, and I the closest thing I came around was a Sanyo OS-CON 16v 180uF from SEP series. According to Sanyo: it has the same specs, but has leads instead of the surface mount.
          There is a 16v cap from the SVP series, but it is 330uF. And there is good availability of 16v 270uF caps on ebay. is 330uF-270uF too high?
          Also, I know that badcaps.net repair service is for motherboards, but do I have the option to send in the graphics card to them? I am not sure of my soldering skills, since this would be my first time soldering a cap.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            digikey and mouser carry solid poly by chemicon and nichicon.
            Same just not Sanyo brand.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Might also find some on ebay.
              Here's Mouser's listings.
              - Check data table in the links for physical size and specs.
              http://www.mouser.com/Search/Product...9N0PDDlQ%3d%3d
              http://www.mouser.com/Search/Product...PXw8vtUA%3d%3d
              http://www.mouser.com/Search/Product...22JGMnSA%3d%3d
              http://www.mouser.com/Search/Product...xjkddbEg%3d%3d
              - Dr Seuss
              • riva2model64
                • Feb 2009
                Thanks for the links, PCBONEZ. The first link looks good since its 8x12.
                • Big Pope
                  Approved Vendor
                  • Dec 2005
                  • 426
                  OS-CON SVP 180uF 16V size also is D8x12mm.
                  My SAMXON Capacitors Database HERE!!
                  X-CON is a new brand for SAMXON's Polymer Capacitors.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    I meant for you to look at ESR too.
                    "and specs"
                    Sorry for not being more clear.
                    - Dr Seuss
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      iirc sep/svp same except sm/thruhole.
