Acer DAA75L Aparker motherboard, CMOS error
  • yoritomo
    • Sep 2012
    • 147
    • Belgium
    Hello all
    I have a small desktop computer, Acer Aspire, no model number on it, label has been removed, but similar to Acer Aspire M3470, at least containing the same motherboard.
    When i start it, i hear to fast beeps which means for this model "CMOS checksum Error" on the screen it has the error message "This bios is exclusively for Acer only" and no other mention or possibility to enter the BIOS setup. I did a clear cmos with the jumper.
    I found the CMOS battery at 0V, even replacing it, the problem still occurs.
    There is a a picture of the Bios area.
    I don't know where is the CMOS chip, should i replace it ? Should it be flashed first ?
    Then to be sure i drained the motherboard residual using the power button as usual, no luck.
    Thank you for your help.
  • yoritomo
    • Sep 2012
    • 147
    • Belgium
    Re: Acer DAA75L Aparker motherboard, CMOS error
    Hello all
    Since yesterday i tried to update the BIOS by the recovery system using a USB stick and the keys CTRL+Home but no luck it never enter flashing.
    USB stick is 32GB formated in fat32 and empty, i renamed the rom as AMIBOOT.ROM and AMIBoot.ROM following the service manual, none worked.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      That Acer message isn't an error and always appears.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • yoritomo
        • Sep 2012
        • 147
        • Belgium
        Hello, thank you for your reply
        Yes i know, but the 2 beeps is an error post meaning CMOS error, and i mean, only this line of post and the copyright notification appears on the screen, the rest of the Bios loading is suspended.
        Should i replace the cmos chip, and will it fix the problem ?
        Otherwise, why the recovery BIOS flash fails in this case, is it too early in the BIOS loading to accept a flash procedure ?
        • yoritomo
          • Sep 2012
          • 147
          • Belgium
          It is sad because it is a small machine but not bad, if i replace the cmos chip does it need to be programmed first ? i never replaced it yet.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Looks like the battery tab is the likely culprit...
            Arc A770 16 GB
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              try now cmos battery and try other ram
              i know it sounds silly but for me 2 or 3 times fixed this msg
              Im Back... sort of...
              • yoritomo
                • Sep 2012
                • 147
                • Belgium
                RJARRRPCGP
                The battery socket has no problem, the power is going on the motherboard and no broken tracks.
                ala-borbe
                I replaced the battery already and the rams too, but no luck it still be always the same.
                • jasko_jacker
                  • Oct 2014
                  • 1137
                  • italy
                  Only a reprogramm bios with programmer should solve this issue, if you make a software bios upgrade with fpt for example not erase all old bios
                  • CasasElectronics
                    Acer 6920G with strange error - sometimes boots and sometimes not, and rare fan noise
                    by CasasElectronics
                    Hi, I've been troubleshooting this PC for a while but I cannot repair it for now.
                    The error on this PC was the known graphics card soldering problem (or that was what I was thinking), so I took a 3470 from a 5920G and installed it.
                    The video after that worked, so I thought the problem was solved. When I tried to install windows, I noticed a problem: the ACER logo (bios load) stopped after completing the loading bar (and that was in every power on, but sometimes not even charged the Acer logo screen, I only could see a blinking white bar).
                    So I thought it may be...
                    02-25-2025, 03:26 PM
                  • samaelvonhell
                    Acer Nitro 16 AN16-41 motherboard: DAZGUMB1AD0 turns off after 60 seconds
                    by samaelvonhell
                    Hello. Could anyone help me with that problem.
                    Laptop model: Acer Nitro 16 AN16-41
                    It had liquid contact and owner dried it up. Dried it so hard that keyboard is all wavy...
                    I've found one drop on motherboard near B+ capacitor, it wasn't short.
                    But motherboard works exactly 60 seconds and turns it self off. Not overheating just exactly 60 seconds. Normally I would say its ME Region problem, but CPU is AMD...
                    In case im attaching BIOS backup
                    08-01-2024, 08:11 AM
                  • Thunderace7
                    Acer Nitro 50 Motherboard
                    by Thunderace7
                    Hi. I have bought a computer from ebay. It is in an Acer Nitro 50 case but was described as NOT being an Acer Nitro. I can find no manufacturer name on the motherboard but it is marked B66H6-AD which makes me believe it is the Acer motherboard that came with the case. It has an Intel Core i3-12100F processor, 16Gb of RAM and an AMD RX560 graphics card.
                    My question is regarding the chip shown circled in the attached picture. I believe this might be the PCH but should it have a heatsink on it? If so, what kind and where can I get one?
                    I have seen the PC working but I am reluctant to...
                    08-28-2023, 05:45 AM
                  • Actionkindaguy
                    MSI MEG Godlike x570 motherboard - need schematic and boardview, USB3 error
                    by Actionkindaguy
                    MSI MEG Godlike x570 motherboard - need schematic and boardview. I have accidentally plugged in the wrong usb plug into a usb3.0 connector on front panel of PC resulting in temporarily shorting out the port. (I know it was really stupid, It was dark in my room and was rushing). I shutdown the computer and now after an immediate restart I get an overcurrent error on boot up saying my PC will shut down in 15 seconds. If I let the computer sit for about 35 minutes, I then can boot the PC without getting error. What I am hoping to find out is what parts were affected by my stupidity. Anyone have any...
                    05-06-2024, 09:41 AM
                  • Sus256
                    HISENSE 65E7KQ PRO - no boot
                    by Sus256
                    Hi all!
                    HISENSE 65E7KQ PRO
                    RSAG7.820.13512 - chassis
                    MT9618BAATAB - cpu
                    RSAG7.820.12059 - power
                    HD650Y3U77 - panel
                    KLM8G1GETF - emmc
                    The TV does not turn on, the standby indicator is on. All voltages are present.
                    Emms is dead. Not readable, not detected.
                    Replaced emmc.
                    But with another dump there is no launch
                    Terminal log
                    UART
                    AC_ON
                    RPMB key is not yet programmed
                    HASH1_VERSION=0x00000000 64bit
                    E-B
                    FDE enabled
                    layout pattern onebin by SAR7,0...
                    06-01-2025, 02:11 AM
