I just bought a biostar Tpower N750, and it has all solid capacitors! Its nice. Didn't see what type of caps they are, but they are all solid capacitors, and I have had no problems with it running a 125W A64x2 5000+, with 2 2gb DDR2800 and a 8600GT.
Biostar with all solid caps
Tags: None
Re: Biostar with all solid caps
I don't know, i've read a lot of reviews, a lot of people rate the T-series biostar boards with Asus's and such.
As for questionable quality motherboards that seem to last, My old ECS rs482-m754 has all OST caps, and it is still running strong after 3 years, thats now in my other computer, replaced by the biostar. And, my quantex QP5 pentium board has a old p1 biostar board in it, Hitano caps, still runs just fine. Even has a temp sensor for the processor (located under the processor.)Last edited by 370forlife; 09-17-2008, 04:45 PM.Comment
But we all know the importance of maintaining the pc case clean and well ventilated. Most PC users don't. Things get even harder when the user chooses looks over ease of maintenance, and locates the case on the floor, with the ventilation openings against the wall. I think here is where the solid caps would help. I didn't bother to read the specs yet, but I have here an intel i945 socket 478 motherboard with five vented electrolytic caps and five solid caps, all on the cpu vrm. The owner complained it was extremely slow, but the damned thing didn't hang up even once. I didn't realize what the problem was until I opened the case and saw the mess inside. The cpu heat sink was full of dust bunnies. It must have been quite hot, and the caps were less than a centimeter away.
So my point is it seems solid caps can stand much more abuse (or neglect) from the user.Comment
Notwithstanding the poor reputation that Biostar has had in the past, my experience with both my (recapped) Biostar M6VLA Socket-370 boards has been exemplary - they're both bulletproof. One is in use as a Linux router, with uptime measured in months (now something like 9 months). My guess is that the bad rep was entirely due to bad caps, and recapped Biostars are rock-solid - just make sure that you give them clean ATX power, and don't use the AT power-supply connector.Comment
Nice to know linuxguru.
I've been looking past Biostar boards even when they have what I want on them.
.Mann-Made Global Warming.
- Dr Seuss
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by jorpecHi,
After a bios update, the motherboard stop to work, only the Re-live screen appears with instructions how to recover the bios, i have follow the instructions, tried multiple pen-drives but it seems the motherboard can't read them, so i thought about write the chip with a memory dump
It has a MX25L8005 chip.
Thanks...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
- Loading...
