Msi ms-7352 post 7575 ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    I got POST diagnostic 7575 and then shut off on MSI MS-7352...
    CPU Core 2 Duo E6550
    Without memory it's C1C1 repeated beep but not shut off...
    WIth RAM it's 7575 few second, two fast beep then shut off...
    Anyone knows what's the issue ?
    cheers
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Re: Msi ms-7352 post 7575 ?
    why dont u use the postcodemaster website for figuring out what the post codes mean?
    • bianchi77
      • Jun 2016
      • 1121
      I got no clear clue from that website, looks like it's HP board...
      • bianchi77
        • Jun 2016
        • 1121
        http://h20564.www2.hp.com/hpsc/swd/p...&swEnvOid=1098
        Is it possible that I got problem with FET, because there were some bad caps that I have replaced now...??
        FET = P09N03BDG
        • bianchi77
          • Jun 2016
          • 1121
          How do you reckon of those FET condition ? I can not read label clearly...could it be burn and making the voltage unstable under stress ( full load ) ?
          • bianchi77
            • Jun 2016
            • 1121
            I've replaced the FET, now it can boot, but asking for system fan...I put a fan already on that connector but still complaining and auto shut off, probably my fan is not compatible ?????
            • bianchi77
              • Jun 2016
              • 1121
              It's fixed already, thanks guys, HP DX7400 mainboard...I'll give you a picture later on..
              • bianchi77
                • Jun 2016
                • 1121
                Photos, I'm done with this board, now doing the test with 3Gb memory, linux and CPU E6550....
                Cheers
                  Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                  Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                  various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                  Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                  trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                  what is wrong with your PC in just seconds. It saves you time and money.
                  Our new and improved design...
                  11-01-2024, 06:29 AM
                • pkslowk
                  Debug Card Error Code and Solution
                  by pkslowk
                  Sr. Motherboard Debug Error Code Solution
                  1 Intel 845 E9 Bios Related Problem
                  2 Intel 845 D4 CPU Socket Related problem
                  3 Intel 845 37 Bios Related Problem
                  4 Intel 845 7C Bios Related Problem
                  5 Intel 945GCPE 34 Bios Related Problem
                  6 Gigabyte 845 2 Ram Related Problem
                  7 IBM Server A6 A7 Ram Mismatch Problem
                  8 Asus 845 29 CPU Related Problem
                  9 Lenovo I946 97 C-Mos Jumper related
                  10 Gigabyte 845 A0 CPU Related Problem
                  11 Asrock G31M-VS D7 Bios Related Problem
                  12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                  01-28-2021, 12:51 PM
                • mosfetratus
                  macbook A2918, orange light off when shut off
                  by mosfetratus
                  When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
                  Works with battery and charges, but when i shut off i get this problem.
                  It had liquid spill. Board has no corrosion, keyboard is working, power button...
                  05-31-2024, 03:34 AM
                • MisterAIL
                  PS5 digital / No Power / No Beep / Good power supply
                  by MisterAIL
                  Brought a non functionnal PS5. Apparently only a bad PSU...
                  No beep, nothing.
                  After some tests i found this :
                  - PSU is fine (12 volts stable)
                  - 12 volts line is shorted
                  - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                  - By the way, nothing change. No signal, no power, no beep.
                  Mesuring all rails with my workbench psu (12 volts input)
                  - 0.00 amp drawing
                  - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                  03-12-2024, 03:24 PM
                • WVUfan
                  PS5 EDM-033 One Beep,No Lights, No Power Troubleshooting Help
                  by WVUfan
                  hello. i've a ps5 edm-033 mobo w/ no power, lights, but one beep when power pressed. i've hooked to uArt and only error code is 80871001 (DDR4 No Power or Short Circuit). i have a donor board, same model, that does power up, fan spins, blue light, and beeps 3 times, then powers off. it has a botched HDMI port replacement job. so w/ the board i'm interested in, with the error 80871001, i was able to research and obtain voltages of the SSD PMIC. i've attached pictures of the provided diagram by DylanBBK (@d62 on Discord) and my voltages and picture of my board. my question is on my picture...
                  Yesterday, 01:12 PM
