ATI 4670 dead
  • Audison
    • Sep 2016
    • 46
    • Slovenia
    ATI 4670 dead
    https://www.asus.com/Graphics-Cards/EAH4670DI1GD3/
    I was not using this card for a while it was sitting in the drawer and after wanting to use it on some computer it would not turn on. It does not even heat up anything. No output on the screen computer just runs fans tried on 3 different motherboards the same result.
    How to understand what is gone wrong on this board? where do you measure? any advice for a noob like me?
    Thanks!
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3261
    • Singapore
    Re: ATI 4670 dead
    what cooler was used on it and does it have a backplate (show a pic)? some coolers can warp the board and kill the bga after a while.
    how was the card stored? make sure it was properly stored in a static bag with nothing ever stacked on top of it. i had a video card that died because of stuff stacked on top of it with no bubble wrap.
    u can also try cleaning the pci-e goldfinger contacts with an eraser and/or isopropyl alcohol. some video cards can become undetectable because of dirty/oxidised contacts. (fock that rohs sheet lol)
    • Audison
      • Sep 2016
      • 46
      • Slovenia
      Re: ATI 4670 dead
      The cooler used on this card was https://www.arctic.ac/eu_en/accelero-l2-plus.html
      It does not have a back-plate but it's really light so I would think it was not the problem.
      The card was not in static bag but there was never anything stacked on top or bellow it.
      I did try to clean the pci contacts before posting here and testing it again but same result.
        master hoarder
        • May 2008
        • 12164
        • Bulgaria
        Re: ATI 4670 dead
        I don't see any chipped off parts (very easy to do if the card wasn't stored properly, hit with another object, or dropped)... So I would say the issue is most likely heat-related BGA problems. One would think the HD4670 is a not a power-hungry video card (and it isn't!), but that's why it often gets an undersized cooler and overheats under load.
        Chances are you can easily revive it with a reflow. Might need to remove the RAM heatsinks first, though, as those could weigh down on the RAM chips during the reflow and either move them or completely fall off.
        • Audison
          • Sep 2016
          • 46
          • Slovenia
          Re: ATI 4670 dead
          Thanks for information. Any advice on doing the reflow? can you do it in the oven at what temps and for how long? Thanks!
            master hoarder
            • May 2008
            • 12164
            • Bulgaria
            Re: ATI 4670 dead
            I don't recommend the oven method. It's very easy to completely destroy the video card, because many ovens (especially electric ones) overshoot the temperatures when started cold. If you really must use the oven method, at least pre-heat the oven to 150-180C before putting the video card in it. Many YouTube videos will not tell you this. In fact, don't rely on those YouTube videos at all - a lot of them are bullshit and/or full of misinformation. There are better ways to reflow the video card, so save this as a last method if nothing else works. In fact, even selling the video card for parts is a better idea than trying to fix it with the oven method.
            Now, if you have a gas stove or burner and a heat gun, that is by far the best method IMO (the gas burner is used to heat the video card from the bottom, and the heat gun is only used to heat the GPU after the video card is pre-heated).
            Second best method is with a gas stove / gas burner only. Just heat the video card from the bottom side (under the GPU chip).
            Third best is heat gun + electric stove used as a bottom heater.
            You can also use just a heat gun by itself, alternating between heating from under and above the GPU chip. But you will need a temperature meter for sure.
            Speaking of which, if you do repair computers somewhat more often or intend to in the future (either as a hobby or professionally), I encourage you to get a $5 type-K temperature meter. They are very easy to find on eBay and elsewhere online. The Lutron TM-902C is a really popular one. You'll find it very useful when doing reflows, because it is much more accurate than an oven thermostat.
            Anyways, as for reflow temperatures, the GPU BGA chip needs to hit around 220-230C and stay in that temperature range for about 10 seconds (this is for lead-free solder, which is what your video card uses). To get to that temperature, though, the whole video card has to be heated slowly (but not too slow). The whole reflow process should last about 8-10 minutes max, then the video card is left to cool down.
            First you start with the pre-heating stage, where you heat the video card to about 150C-180C. Should take you about 2-3 minutes to get to that temperature. Then you leave the video card at that temperature for 30-60 seconds. Then you start ramping up the temperature until you hit the reflow solder temperature mentioned above. Should take you another 3-5 minutes for that. Then you turn off all heat and let the video card cool slowly.
            Last but not least, DO NOT cover the video card in tinfoil / aluminum foil. Again, a lot of videos on YouTube tell you that you should. But it's a really bad idea with really bad outcomes usually.
            In the past, I used to recommend people to use flux when doing their reflows, but I no longer do that, because people tend to over-apply it and make a huge mess in addition to destroying the hardware they were trying to repair. Moreover, what flux you get is very important, as not all fluxes are suitable for reflowing (the rosin ones, for example, evaporate and dry out too quickly, leaving a thin layer on the surface of the solder that nothing can adhere to). So skip the flux altogether.
            • Audison
              • Sep 2016
              • 46
              • Slovenia
              Re: ATI 4670 dead
              Great information momaka! Thank you very much! I will try doing reflow on a few dead cards I have lying around first and than try to fix this one.
                master hoarder
                • May 2008
                • 12164
                • Bulgaria
                Re: ATI 4670 dead
                You're welcome!
                By the way, I have a curious question: what other dead video cards do you have? Just wondering, because you may be able to revive those as well.
                Also, I forgot to mention this important bit of info: if your video card has any electrolytic capacitors, definitely avoid the oven reflow method, as that is a sure way to pop the caps. Even solid caps can get cooked and die in the oven. This is one of the many reasons I am so vocal against the oven reflow method.
                When doing a reflow on the stove or with a heat gun, at least you can place the card in such a way that any electrolytic caps do not get as much heat exposure.
                I usually place a metal grille about 4-6 cm (about 2-2.5 inches) above the burner on my gas stove, and put the stove on the lowest flame first. Then I place the video card with the GPU facing up. The bottom side of the GPU should be more or less in the center of the flame's top. The flame from the gas burner should NOT touch the video card.
                • Audison
                  • Sep 2016
                  • 46
                  • Slovenia
                  Re: ATI 4670 dead
                  NV GF7300GS 256MB DDR2 TV DVD PCI-E - works for few minutes than no more display output
                  GV-NX84S256HE rev 1.0 - displaying green artifacts
                  GV-84G256HE rev 2.0 - just dead
                  GV-NX84G256H rev 2.0 - dead
                  I will post some pictures later when I get hands on the camera.
                  Also all listed cards have passive cooling so they overheat all day so this might be a problem here.
                    master hoarder
                    • May 2008
                    • 12164
                    • Bulgaria
                    Re: ATI 4670 dead
                    For these two, it's a coin toss whether you will get them fixed. The GeForce 7 and early 8 series have the bumpgate issue (where the GPU core separates from the GPU substrate). But give the reflow a try anyways and see what happens. If they do get fixed, definitely make sure they run and stay cool (under 60C core temperature under maximum load).
                    Since these are revision 2.x, they may be based on the GeForce 9400 GPU core, so it's possible they don't have the bumpgate issue. Good chance you can bring these back with a reflow.
                    Though in my personal experience, nVidia has always been problematic when it comes to reflows. ATI, on the other hand, I've had very good success at reviving.
                    Yes, you are 100% right about that.
                    Generally, all you really need to do to fix that is just put a 80, 90, or 120 mm fan in the case and have it blowing air towards the video card (doesn't matter from which direction). You can run the fan on 5V instead of 12V to get silent or near-silent operation. That way you can keep your passive cards cool without adding any noise to your PC.
                    Testimony that this works:
                    https://www.badcaps.net/forum/showpo...9&postcount=31
                    • Drack
                      Yup it's me
                      • Nov 2016
                      • 297
                      • Venezuela
                      Re: ATI 4670 dead
                      So what happened?
                      • double_DD
                        How can I be sure that my EC chip is dead?
                        by double_DD
                        As the title suggests, how can I be sure that my EC chip is really dead?
                        I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                        Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                        03-12-2025, 07:47 AM
                      • jm1234
                        microwave rotary switch contacts go bad requently
                        by jm1234
                        Hi, I have a 11 year old microwave Siemens and the main function selector switch is a rotary type. It goes bad every few months, there are carbon (?) pads and the metal contacts that drive on them create concentric circle tracks from the residue.
                        I clean the tracks and the metal contacts with IPA and it works few months again. Here you can see the contacts:
                        Once I tried this contact cleaner: Kontakt 60 https://www.tme.eu/Document/3f58feb2...TAKT60.DTE.PDF, but it only lasted few weeks, so probably not a good choice.
                        Is there any...
                        05-04-2025, 10:45 AM
                      • disorder
                        ps5 edm-033 dead after hdmi/usb ports destroyed
                        by disorder
                        hello guys,
                        i need help to repair a edm-033 ps2
                        history : as always hdmi port and usb ports destroyed after unplugged
                        after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                        so i changed it
                        now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                        but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                        i don't see any projection of liquid metal on pcb.
                        01-14-2025, 12:48 PM
                      • Beton
                        Finding a dead short component
                        by Beton
                        Hi guys!
                        I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                        So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                        I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                        I have a bench PSU and if I try to inject voltage the voltage...
                        12-10-2021, 01:05 PM
                        HP EliteDesk PC EliteDesk 800 G1 con factor de forma reducido (ENERGY STAR) EliteDesk 800 i5-4670 Specification for Upgrade or Repair
                        This specification for the HP EliteDesk PC EliteDesk 800 G1 con factor de forma reducido (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk PC EliteDesk 800 G1 con factor de forma reducido (ENERGY STAR) boardview and EliteDesk PC EliteDesk 800 G1 con factor de forma reducido (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can...
                        09-12-2024, 03:30 PM
