DDR2 for Intel and AMD ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    I got some memory modules worked well on AMD motherboard but I tried them on Intel motherboard, it didn't work....did I get compatibility issue ?
    May be the motherboard manual can tell me which one is compatible ?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: DDR2 for Intel and AMD ?
    If it's 4gb sticks I'm not surprised. If they are 2gb, they usually always work in both platforms.
    • bianchi77
      • Jun 2016
      • 1121
      It's 2Gb and 1Gb 800MHz...
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        Indeed, usually good motherboards have a list of memory modules that were tested with it written in its manual. I've never tried 4GB modules before, highest I've used are 2GB and so far so good (all Intel motherboards...)
        • bianchi77
          • Jun 2016
          • 1121
          could it be because of incompatible CPU I used celeron D 340...and I can't find it in a compatibility list :
          http://processormatch.intel.com/Proc...entName=dg31pr
          • electromaster84
            • Jul 2015
            • 35
            It could be high density memory. High density ram will work with AMD but won't work on Intel boards.
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              More important than the CPU , you should check the bus speed of the board , and what Ram it takes . So start with the Intel board manual first . Evenmore , some Intel boards requires buffered Rams and others , non buffered . If the Rams are 533 or even 667 MHZ , they might not work on boards that requires 800 Mhz bus speed .
              Add to that , not finally , that some Intel boards within third party manufacturers , require double channel alignment or Channel A and channel B proper placing .
              • mockingbird
                • Dec 2008
                • 5488
                It depends on the board.
                Asus boards are pretty forgiving with memory. For example, DDR2 ECC modules will work on them (unbuffered ECC, not PC2-xxxxP that has the larger IC in the center of the module), whereas they will not on Foxconn boards. Some older Asus Athlon boards will even take Registered memory (But not FB-DIMMs).
                Either way, there exists a piece of software that allows you to change the SPD of a module. It used to be free, but the author now charges money for it. So theoretically if you change the SPD of a stick that should work with information with one that does work, you might get lucky.
                It's probably also handy for modules that have an SPD that says the chips are imited to 667 whereas they are actually DDR2-800 chips.
                • R_J
                  • Jun 2012
                  • 9638
                  Are you looking for spdTool_063.zip? if you search you can still find it
                  • mockingbird
                    • Dec 2008
                    • 5488
                    No, that's not it...
                    The name of the software is Thaiphoon Burner.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      I am not really understanding this?
                      The Celeron D340 is for a PPGAE478 socket Ie it should have 478pins?
                      Motherboard DG31PR has a LGA775 socket ie processor should have 775 pins?
                      If that is correct then I will be surprised if you have not caused damage to both processor and motherboard.
                      • mockingbird
                        • Dec 2008
                        • 5488
                        There are two version of the 340. The 340 is Socket 478, and the 340J is LGA775.
                        • selldoor
                          Slow Learner
                          • Dec 2010
                          • 7870
                          Thanks- Maybe if the OP had said D340J I would have remembered. Though it is some years since I played with these CPUs.
                          Whilst it will physically fit, the fact that it is not on the compatibilty list should be a good clue that it will not work, though IIRC, it was a grey area
                          as some boards would work some wouldnt and some would on a bios upgrade?
                          @OP perhaps try with one stick of ram in case the two are incompatible.
                            Intel Core i7-900 Desktop Processor Extreme Edition Series Datasheet
                            The Intel Core i7-900 desktop processor Extreme Edition series and Intel Core i7-900 desktop processor series are intended for high performance high-end desktop, Uni-processor (UP) server, and workstation systems. Several architectural and microarchitectural enhancements have been added to this processor including four processor cores in the processor package and increased shared cache.
                            The Intel Core i7-900 desktop processor Extreme Edition series and Intel Core i7-900 desktop processor series are the first desktop multi-core processor to implement key new technologies:
                            10-23-2024, 02:56 AM
                            HP ProLiant xw460c ProLiant 5120 Specification for Upgrade or Repair
                            This specification for the HP ProLiant xw460c can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProLiant xw460c boardview and ProLiant xw460c schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                            09-12-2024, 02:15 PM
                            HP ProLiant xw460c ProLiant X5260 Specification for Upgrade or Repair
                            HP Pavilion p6061uk Pavilion p6000 Q8200 Specification for Upgrade or Repair
                            This specification for the HP Pavilion p6061uk can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion p6061uk boardview and Pavilion p6061uk schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                            09-12-2024, 03:36 PM
                            Acer Swift Acer Swift 3 SF314-511 14 inch Laptop - (Intel Core i5-1135G7, 16GB, 512GB SSD, Full HD Display, Windows 11, Silver, Intel Evo Certified) Notebook 3 Specification for Upgrade or Repair
                            This specification for the Acer Swift Acer Swift 3 SF314-511 14 inch Laptop - (Intel Core i5-1135G7, 16GB, 512GB SSD, Full HD Display, Windows 11, Silver, Intel Evo Certified) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-511 14 inch Laptop - (Intel Core i5-1135G7, 16GB, 512GB SSD, Full HD Display, Windows 11, Silver, Intel Evo Certified) boardview and Acer Swift 3 SF314-511 14 inch Laptop - (Intel Core i5-1135G7, 16GB, 512GB SSD, Full HD Display, Windows...
                            09-07-2024, 03:10 AM
