Albatron PX865PE PRO - Light, Fans, but no Action
  • Agent24
    I see dead caps
    • Oct 2007
    • 5019
    • New Zealand
    Picked up a nice server case with PSU for cheap 2nd hand ($10!) which included an Albatron motherboard (Socket m478) and 3Ghz Prescott
    Seller said either board or CPU or both was faulty, (no POST - apparently it was fine one day and then dead the next - but who knows how much of that is true?) but I took them anyway in the hopes that at least the CPU might be still alive
    Apart from light dust around the CPU everything looks fine. Capacitors are all Chemicon KGZ and don't look dodgy
    Board will start, standby light comes on, fans go, but no beeps (not even with no RAM or Video) and nothing on screen.
    Do you think it's the capacitors? or anything else this board series may be known for?
    -David VanHorn
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Albatron PX865PE PRO - Light, Fans, but no Action
    Could also be its BIOS chip corrupted by a bad flash - would account for no beeps (not even with no RAM or Video)
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • Agent24
      I see dead caps
      • Oct 2007
      • 5019
      • New Zealand
      I had considered that, but can't really do much as it's not socketed. Unless it's possible to reprogram in-circuit, or someone wants to be very nice (and rich!) and give me an SMD rework station
      Although assuming the truth is that it just stopped working by itself, I find that unlikely. (although I guess the chip could have randomly failed)
      -David VanHorn
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        time to play swaptronics.
        try the proc in something else.
        • Phenos
          • Oct 2006
          • 46
          Are you sure that all the caps are "Chemicon KZG?" I recapped around 8 of the same type boards here.
          The 1000uF 6.3V caps scattered around the boards where bloated GSC caps.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5019
            • New Zealand
            The only other intel hardware I have is socket 370 or lower. Only AMD for my new builds. I've got a friend who has a P4 something but I doubt his board supports prescott. Probably have to see if there's any local places I can take the CPU to and test it.
            There could be a reason for that, I discovered that this board is actually v2.0 - according to Albatron, nothing changed except the onboard LAN and Audio chips are slightly upgraded. But maybe they changed the caps too. Everything down to 1000uf is KZG. Everything lower is G-Luxon. None of them look dodgy
            -David VanHorn
            • Agent24
              I see dead caps
              • Oct 2007
              • 5019
              • New Zealand
              OK, so I checked out the CPU (by buying another board, a cheap Asus P4S800-MX) which works fine. So it would appear that Mr. Albatron is broken. Maybe his BIOS chip is stuffed full of 0s, or otherwise useless data.
              I'm currently thinking of a theory that I could make some sort of interface out of a PLCC socket and 32 pieces of (short of course) wire, that could be put over the chip and use to check/reprogram it without having to desolder it (which I can't really do). Not sure if that idea would work, though.
              oh and the bit about it running fine is a little... hyped. Upon entering BIOS to check CPU temp, I noticed the 12v rail was flashing red. Then I noticed it wasn't 12v. It was 10.9v - not exactly spectacular. Checked it with my DMM which said 11.11. seems just a little out-of-spec to me.
              I'm thinking this may be attributed to the Prescott core wanting more power than the brilliant feat of engineering that is a Chiefmax 420w PSU with 18A on 12v is wanting to give. I hope.
              I guess I'll rip out my Enermax and see what difference that makes
              -David VanHorn
              • Agent24
                I see dead caps
                • Oct 2007
                • 5019
                • New Zealand
                Whoops, actually it was Chieftec PSU which is indeed it seems not up to the task. My Enermax is currently doing a nice 11.96v
                I wonder if the low voltage from the Cheiftec was the cause of Mr. Albatron's demise? does this seem possible?
                -David VanHorn
                • Harvey
                  • Apr 2007
                  • 264
                  Have you measured the VRM voltage on the FETs to see if there's any sign of life?
                  Failing that, try warming the CPUs VRM capacitors up with a hairdryer for a few minutes before powering up - sometimes it can just give them a little bit of life to get things started.
                  • emil_t
                    RTX3090 working fine but fans not spinning
                    by emil_t
                    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                    04-12-2024, 06:54 AM
                  • GlennB1975
                    DFI EL336 motherboard cpu fans run but reset light lit on pci analyser
                    by GlennB1975
                    Hi there.
                    First of all thanks for having me. I’ve posted in the introduce yourself section a little bit about myself.
                    I have recently purchased two faulty motherboards for a fruit machine that i have, these PC’s are getting very hard to find now with them getting older, so seeing as ive had a bit of experience with repairing Nintendo DS’s i thought id try my hand at PC repair too.
                    The first motherboard(ive not looked at the second one in any detail yet) has an issue which it will start up, the CPU fans spin but it does not post to BIOS, I get a slight...
                    03-07-2024, 09:10 AM
                    Lithonia Lighting versus Light of America Compact Fluorescent product quality
                    I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                    I also have back when Light of America had these light bulbs available for yard lights
                    The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                    While the Lithonia lighting fixture has all most certain bulb failure
                    So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                    I have only had this light fixture for not more than a year if it...
                    07-02-2023, 03:45 PM
                    LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                    This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-07-2024, 03:40 AM
                    LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                    This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 09:10 PM
